help
Old Nov 24, 2012 | 11:08 AM
Cheri Wagner's Avatar
Cheri Wagner
4th Gear
Default help
I have a 1991 corvette hereis the problem she will start and then shuts off we have change the computer the oxygen sencor fuel pump fuel filter anybody have any ideas
Old Nov 24, 2012 | 12:42 PM
summerst's Avatar
summerst
Does the car still have the original injectors? If so, ohm check them. Should be about 14 or 15. If you have one reading 6 or under, that may be your problem.
Old Nov 24, 2012 | 02:21 PM
Railroadman's Avatar
Railroadman
St. Jude 15 Year Donor
St. Jude Donor '09 thru '26
First, welcome to the forum. Collectively, this place can solve any problem you have. The only requirement is pics of the car.
You will find most folks here try to take a systematic approach to problems. Don't just throw parts at it, find out WHY it's acting up and then fix that issue.
After the car dies, does it then re-fire right away? Or do you have to crank a lot, or maybe walk away and then come back later?
Old Nov 24, 2012 | 03:23 PM
Cheri Wagner
4th Gear
Thank you so much that seems to be the problem 2 of the injectors were bad again thank you Have a great Holiday cheri
Old Nov 24, 2012 | 04:16 PM
mrmtrtrnd's Avatar
mrmtrtrnd
Glad it's up and running again and welcome to the forum Cheri.
Old Nov 24, 2012 | 10:00 PM
AirForceOne!'s Avatar
AirForceOne!
We would love to see pictures of your 91 when you get a chance to post them!
Old Nov 24, 2012 | 11:19 PM
Railroadman
At least the writing is not pink!
Old Nov 24, 2012 | 11:21 PM
Frizlefrak's Avatar
Frizlefrak
Yet.
To help
