Smart key + push to start +keyless entry+ remote start
my door locks arent working at the moment, the buttons work and i can hear the actuators clicking, and the little levers move slightly but the doors dont lock, so I planned on tackling it all at once.
Plus imagine walking out to your crazy custom vette with a buddy or a date, clicking a button and your car starts up and roars like a straight piped monster of a vette. or jujst walking up to your vette without keys in your hand and the parking lights flash and you hop in push a button and go.
http://www.advancedkeys.com/Prod_AK104B.html
I ran across this, I was looking into keyless entry to begin with because its very handy but with this system you can have everything.
If I did do this I would keep the lock cylinders on the door and a pair of keys as a triple security to electronic failure, as well as the key ignition (just make a removeable cover or something for the steering column key ignition port)
My question is this possbile? I know I can mount the button, remove the steering wheel lockout cable and pin, and the cable that runs to the plunger in the steering column that requires you to have the car in reverse (4+3 trans) to remove the key. Ive already disabled my clutch safety switch because it burnt out on me.
it looks pretty much splice and play to me in addition to disabling the safety features on the steering column
just need to splice into the ignition, brake input, door lock actuators(positive I believe is what our locks are) Possbily would do the auto window closer, so the window motor, and the hazard lights. then hide one of the antennas under the hood and one in the rear where the very rear of the hatch closes.
thoughts? and I dont care if you think its a pointless waste of money time and effort or originality. The interior is already going to be completely different from stock, I have a double din touch screen im modifying the center console to fit, new sound system, making fiberglass door panels, and an 8 inch sub in one of the rear compartments ect. im looking for input from electrical savy people that can think of problems id run into.
cheers!
I thought about that, Id just make sure I didnt put it in gear before I left the car. Im sure there some wire to tap into that tells the car is in neutral somewhere, which in that case I could splice in a relay in there.
Only on an auto as I stated above
The clutch switch is the starter safety device on a stick car
You would need switches on the shifter or shifter linkages to indicate neutral position
And this is a liability issue waiting to happen. You need to be very careful about remote starters and manual cars.
possibly something on the overdrive unit? maybe something to do with the switches that control what gear your allowed to be in with overdrive?
I don't know of any remote start + push-button ignition modules that are manual compatible. However, if you forego the push-button, there are several good remote start systems that might work.
The computer only needs to know when the car is in gear with a auto so it can adjust the idle speed;
something not needed with a manual car
Not connected to anything in the car ,just stops power to the O/d unit
a 1st gear switch that is open when trans in 1st
a 2nd gear switch that is open in 2nd
a 4th gear switch that is closed in 4th
Depending on what the remote setup controller requires for out of gear indication; 12V or a ground ???
you would have to design a circuit ( going to need some relays ) using those switches on the trans to give the required signal
I didnt see any requirements about gear indication, if its for an automatic the car is either going to be in park or neutral regardless so.
still doesnt rule out the possibility of starting in reverse or 3rd, more concerned about reverse then third.
another hurdle to jump over, what about putting the car in the "ON" position? so I can check codes, listen to music with the car off ect.
http://www.advancedkeys.com/docs/AK-PSB05.pdf
Neutral Safety switch
Required for remote start operation , this will prevent remote starting while in a drive gear
Maybe not , some people just turn the key off , pull the park brake on and jump out without checking
