it is fixable
Old Dec 3, 2012 | 11:52 PM
84VetteMan205hp's Avatar
84VetteMan205hp
Default it is fixable
can i soder the clip back on its been off for 7 or 8 years and its time to fix for level 1 emissions test.
Old Dec 4, 2012 | 04:54 AM
Keystring's Avatar
Keystring
Go to either Radio Shack or an auto parts store and buy a new crimp on connector.
The usually come in packets of twenty or more but are inexpensive.
Just cut the old one off, strip the wire back about 1/4 inch and crimp the new end on.
No soldering required (unless you want to for your own peace of mind).
Old Dec 4, 2012 | 06:23 AM
AirForceOne!'s Avatar
AirForceOne!
What the hell is it?
Old Dec 4, 2012 | 07:48 AM
wdurham's Avatar
wdurham
Yeah, what is it? I thought it was the wire for the horn, inside the steering wheel hub, but that isn't part of emissions tests.
Old Dec 4, 2012 | 10:30 AM
383vett's Avatar
383vett
I've got an 84 and have removed just about every nut and bolt on the car. I have no clue what that is.
Old Dec 4, 2012 | 10:33 AM
The Plastic Lizard's Avatar
The Plastic Lizard
It is absolutly the horn contact switch from an early c4.
he must need an emissions AND a state inspection test....need the horn for the second.
Old Dec 4, 2012 | 12:07 PM
jhammons01's Avatar
jhammons01
LOL...add another to the list that has never seen that part.....
Old Dec 4, 2012 | 01:42 PM
ch@0s's Avatar
ch@0s
It's a common part on old GM vehicles and most steering wheels for that matter. It goes in the hole and rotates to lock in. it grounds the horn button via the clip in the picture.
Part C in this picture.
Old Dec 4, 2012 | 03:59 PM
wdurham's Avatar
wdurham
I recognized the spring with the wire through it and the contact on the end, plus the black collar in the first photo. My 92 k2500 HD silverado had the same wire. That broke in freeway traffic in Dallas one day and the horns went to blaring. I got flipped off by many people as I tried to find an off ramp.
I couldn't tell what the other photos were.
Old Dec 4, 2012 | 05:59 PM
84VetteMan205hp
o yeah i meant to say that.
Old Dec 4, 2012 | 06:00 PM
84VetteMan205hp
second picture is inside the steering wheel ant the third pic is the back of the steering cap
Old Dec 4, 2012 | 06:01 PM
84VetteMan205hp
thats what happen when it broke 7 or 8 years ago at 7/11
Old Dec 4, 2012 | 08:28 PM
wdurham's Avatar
wdurham
I would bet you could solder it back together, or go to a salvage yard and pull one from another GM vehicle from that era. Even the black collar with the keyed tabs looks like the one from my 92 truck.
It has been years, but I recall soldering the wire, possibly to a small lug, to repair mine. If the tube the collar slides in and locks into, is still intact you should be able to do something similar.
Old Dec 4, 2012 | 08:42 PM
ch@0s's Avatar
ch@0s
As stated, all he needs to do it put another female spade on the end and go.
Old Dec 4, 2012 | 11:19 PM
Frizlefrak's Avatar
Frizlefrak
Exactly how I fixed mine on my old 84 ages ago.
To it is fixable
