Winter Storage
Old Dec 8, 2012 | 12:54 PM
cessnaguy1965's Avatar
cessnaguy1965
Default Winter Storage
Well, it looks as though winter is officially upon us. Time for me to swap positions in my garage with my 94 six-speed coupe and Polaris snowmobile. Before I do the swap though, I plan on changing the oil, full grease job, and packing the fuel tank with high test gasoline and some sort of winter stabilizer. Wash job complete, the cover will go on and I plan starting it up every week or so and letting it idle up to operating temp. I would like others to chime in on possible suggestions that I could add to the list and what they do to store thier babies for the winter season. Unless it is an exceptional day out, i.e. warm and dry, I do not plan on driving it until warmer weather. Anything I am missing?? What type of fuel stabilizer is recommended, if any at all?? Thanks in advance for all input.
Old Dec 8, 2012 | 02:45 PM
Leftoverture's Avatar
Leftoverture
I fill my tires to about 34psi as an anti-flatspotting measure. Probably doesn't do that much good, but can't hurt. I use Sta-bil in mine and make sure to run it long enough for it to reach the engine (I usually just put it in at the gas station when I'm doing my winter fill, that way it gets mixed and run through on the way home). Starting it weekly during the winter can have mixed results as you create a lot of moisture in the car during cold starts. I start mine about once during the whole winter storage, usually on a nicer day. I do not use a battery tender, opting to make sure the battery is fully charged then I just disconnect it. A fully charged battery cannot freeze so it stays good all winter with no risk of over charging.
You'll get many opinions on winter storage techniques. There are pros and cons to each so I just go with what has worked for me for ten plus years of storing classics.
Old Dec 8, 2012 | 04:55 PM
abdo's Avatar
abdo
2016 C1 of Year Finalist
I put my '86 up on jack stands so I don't have to worry about the tires flat spotting. It also gives me a chance to work on the underside for some cleaning. I don't start it up during the winter storage as it tends to create moisture problems. Most Corvette owners I know do not start it up. I also hang a product called Damp Rid inside to absorb moisture. I put a battery maintainer on the battery once a month and have the battery disconnected. Everyone has different opinions about storage.
Old Dec 8, 2012 | 05:14 PM
FirstC4's Avatar
FirstC4
Mine is usually only put away for about 4 months. I do
-oil change
- inflate tires to max psi
- wash
- remove battery
- moisture packets for interior
- cover
Old Dec 8, 2012 | 05:46 PM
96polovette's Avatar
96polovette
I use bounce fabric softener in the cabin and the engine area to keep the mice away from it. I have never had a problem with mice. And it smells better than moth *****. I remove the battery and bring it inside. I put it on jack stands to prevent any flat spotting. I start it about once a month and run it for about 20 minutes up to operating temperature. I have never had any moisture problems, any moisture in the fuel system quickly burns off. I would love to one day have a house with a garage door that opens into the basement with enough room for at least two cars. That would be an ideal way to work on them year round as the winter season is a great time for that.
Old Dec 8, 2012 | 08:05 PM
theadmiral94's Avatar
theadmiral94
From: 1994 LT1 Coupe 6-speed with FX3 & 2000 LS1 Vert 6-Speed with F45 Hunterdon County, NJ
I also put a piece of cardboard under each tire -- it further insulates the tire from the cement and works better at preventing flat spotting than the increased tire pressure (which I also set to 34).
Running the car occasionally to coolant operating temp will NOT bring the oil temperature up to 200+, which is required to burn off the moisture created during the previous run to prevent the moisture from turning into acid in the oil. So better to not run it.
However, if running it, also turn-on the A/C to lubricate the pump and seals. Also try and turn on/off heating system and all electrical devices to exercise their relays.
If using dino oil (non-synthetic), consider changing the oil again in the spring (read why at bobstheoilguy.com).
If the battery will constantly experience much lower than 20 degrees F, remove or trickle charge - as even a fully charged battery has some pure water in it and could freeze and crack the case -- esp as all batteries self-discharge over time.
Old Dec 8, 2012 | 08:08 PM
Vette Daddy's Avatar
Vette Daddy
I never put mine away for the Winter. I drive it around enough to get it up to operating temp when the roads are dry. At least once or twice a week, depenging on the weather.
Old Dec 9, 2012 | 07:44 AM
Paul Workman's Avatar
Paul Workman
Once or twice a month for me. IMO, a car suffers more from not using it tha from at least an occational bit of exercise. So, the Z gest a couple 7+k blasts; gets the tires and the oil warmed up pretty quick, and back in the stall with the Battery Tender minding the store till next opportunity. Same goes for Ami's C3.
It seems to me I have less problems with them come spring than I do if I let them sit. Same goes for the lawn mower and the standby generator: they (carb jets or injectors, the relays and hydraulics, etc, etc) seem to appreciate the exercise!!
P.
P.
Old Dec 9, 2012 | 11:43 AM
ozzyrulesme's Avatar
ozzyrulesme
Sea foam in full tank of gas
Plywood under tires
Battery tender on .
Cover on
Wait for spring!!
Old Dec 9, 2012 | 11:56 AM
motor city dave's Avatar
motor city dave
St. Jude Donor '16
Same here.
Old Dec 10, 2012 | 12:22 AM
cessnaguy1965
Great tips. Never thought of the cardboard or plywood under the tires trick, but will do just that. I believe I will remove the battery and put it in my basement as I only have a charger and not the tender. Also will go to the nearest dollar store and pick up the fabric softener sheets. Gotta smell better than my garage. Until spring time, I will pray for lots of snow so the Polaris Ultra can get some miles on it. Thanks all..Cessnaguy
Old Dec 10, 2012 | 02:00 AM
gerardvg's Avatar
gerardvg
Well we am lucky here in Australia, it only snows high in the mountains several hours drive away. Comparable weather to L.A in Melbourne, further north more like Florida with extreme heat far north. Maybe consider a move to California and drive her all year long and stop shivering
The worst thing you can do to a car is not drive it regularly , i feel bad if i leave my vette in the garage for a week.
To Winter Storage
