crazy sighting
Old Dec 8, 2012 | 06:52 PM
84VetteMan205hp's Avatar
84VetteMan205hp
Default crazy sighting
well yesterday i changed my radiator and today i changed my thermostat but i happily noticed, that there was no thermostat in my car so im wondering what kind of damage could this have caused over the 8 or so years we have owned it 6 years of non op.
Old Dec 8, 2012 | 07:35 PM
Vette Daddy's Avatar
Vette Daddy
Won't hurt it at all unless it overheats. I'd install one though, personally.
Old Dec 8, 2012 | 07:37 PM
JackDidley's Avatar
JackDidley
No damage. I dont see it running too cool in Arizona.
Old Dec 8, 2012 | 09:06 PM
84VetteMan205hp
it was overheating i installed 1 and the radiator and the radiator started boiling why is that at the moment it had mostly water in it with some 50/50 prestone antifreeze
Old Dec 9, 2012 | 11:56 AM
fredd1's Avatar
fredd1
Water pump o.k.? What temperature thermostat did you install?
Old Dec 9, 2012 | 12:12 PM
84VetteMan205hp
im not sure about the water pump as im going to post a thread about that in a few mins, but 185
Old Dec 9, 2012 | 12:53 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
OMG!!! It's going to overheat b/c the "coolant will flow too fast and not cool!! Put a thermostat in there immediately so it will run cooler!!
Seriously, I saw that you put one in and it's running hotter (which actually makes sense). Check your radiator when it gets hot; if the radiator is hot everywhere, you water pump is working.
Old Dec 9, 2012 | 01:05 PM
84VetteMan205hp
yeah but my radiator was boiling
Old Dec 9, 2012 | 01:31 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
What does that mean, "My radiator was boiling"?
Your radiator can be COLD, and you can still hear boiling, and have "boiling over" in the over flow tank from heat in the ENGINE. We need to confirm your water pump, by confirming that water is circulating. This can be identified by observing a relatively even temperature though out the entire cooling system, once up to temp. If you engine is 200* and your radiator is 85*F, water is not circulating.
Old Dec 9, 2012 | 02:31 PM
84VetteMan205hp
the water inside the radiator was boiling
Old Dec 9, 2012 | 05:25 PM
Frizlefrak's Avatar
Frizlefrak
Coolant raises the boiling point of water, as well as reducing the freezing point. Straight water is a bad idea.
There isn't much to your cooling system. A radiator and fan, hoses, thermostat, water pump, heater core and hoses, and the water jacket in the engine. That's it. Ensure each is working OK.
If the coolant is circulating at proper speed, the radiator is unobstructed internally and externally, and sufficient air is flowing through the radiator, it won't overheat. Period. Well....with a couple of exceptions.
If the cooling system is 100% and it's running hot, check for three things; A vacuum leak, exhaust obstruction, and retarded ignition timing.
My old 84 (with a manual fan switch) would idle all day long in heavy traffic at 195 degrees in 110 degree ambient temps. Click off the manual switch, and it would cycle between 228 and 213. Yours should do the same.
Old Dec 9, 2012 | 05:41 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
So....the entire radiator was HOT? You're not really answering the question. The ENGINE is what will boil the water...not the radiator. THe water in the radiator could be COLD, and the bubbles created by boiling water in the ENGINE would migrate to the radiator (no where else to escape) and make it LOOK like the "water in the radiator is boiling", when in fact, that is not where the water is boiling.
If you want us to help you, help us. Give us some specific info and more info on the conditions under which it over heats, please.
Old Dec 9, 2012 | 05:48 PM
Frizlefrak's Avatar
Frizlefrak
,If you want us to help you, help us. Give us some specific info and more info on the conditions under which it over heats, please.
Idle? Cruising? Highway?
Is the fan kicking on? Coolant circulating? Heater working? System holding pressure? What is base timing set at? How many inches of vacuum at what elevation?
Throw us a bone.
Old Dec 9, 2012 | 07:16 PM
84VetteMan205hp
Throw us a bone.
not sure about the timing or vacuum but the a/c nor the heater is working.
cruising and the fan stays on all the time
Old Dec 9, 2012 | 07:28 PM
84VetteMan205hp
ill flush all the water out of the radiator and put in the green oreillys brand coolant and see what that does
Old Dec 9, 2012 | 11:30 PM
Frizlefrak's Avatar
Frizlefrak
Why? Previous owner wired it to run continuously? Sounds like they were trying to fix an overheating issue without bothering to trouble shoot it.
You said you replaced the radiator, so I'm assuming there's no debris on the front of it. Once you put a 50/50 mix of coolant in, ensure that it is circulating. Once you know it's circulating, ensure that the system is building pressure and holding it. Also, check your hoses and ensure they aren't collapsing, particularly the bottom hose.
Old Dec 9, 2012 | 11:44 PM
84VetteMan205hp
previous owner before my uncle had some serious issues and he did alot of quick fixes on the car there was pudy around the thermostat housing. this guy was loosing his kids i found the papers stuffed under the passenger seat along with a little 8 or 9 year old dime bag or Cocaine, im glad that i found it though because if the cops found it, it could of killed my teen years and i would of lost my car
To crazy sighting
Old Dec 10, 2012 | 12:24 AM
Phat98's Avatar
Phat98
OMG!!! It's going to overheat b/c the "coolant will flow too fast and not cool!! Put a thermostat in there immediately so it will run cooler!!"
Reminds me of what one of my old drag-racing buddies used to say when discussing this..."Does that mean if I stand naked on top of Mt. Everest I won't freeze because the wind will be blowing right past me?"...
Old Dec 10, 2012 | 12:39 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
That's interesting. THe blower fan doesn't blow? Or the fan blows cold air? If it blows cold air, you're not circulating water.
Old Dec 10, 2012 | 11:58 AM
Slow_Lane's Avatar
Slow_Lane
Just to be clear..the car will overheat without a thermostat. The thermostat serves two very similar functions..when the engine is cold it allows the engine to warm up obviously but it also cycles on and off as you drive under normal circumstances think of it this way....
Engine heats up coolant in block, thermostat opens allowing hot coolant to flow to radiator and "cold" coolant to flow into block. Thermostat closes briefly. During this moment the radiator is removing heat from the "hot" coolant the the whole cycle repeats. Without the thermostat the flow is never interrupted which reduces radiator efficiency and thus the ability to cool (remove heat) from the coolant. Now on most days this might be fine but under extreem use all heat is transfered throughout the cooling system without interruption for heat removal resulting in overheating. Not as quickly as a closed thermostat but it will overheat nonetheless.
Hope this makes a little sense.
Dave
