Replace 1988 centre cap bolt
Old Dec 22, 2012 | 03:36 PM
richard88vette's Avatar
richard88vette
5th Gear
Default Replace 1988 centre cap bolt
Hi all, the centre cap security screws on my 88 are well and truly mashed up, probably as a result of a previous owner having lost the key and just getting a slot cut in the head. Anyway, I'm wondering could I simply replace them with 10mm stainless steel socket head cap screws? Any likely problems? Thanks in advance.
Old Dec 22, 2012 | 06:18 PM
black88z51's Avatar
black88z51
of course you could. Also they've got reproduction replacement locks that are identical for sale too.
Old Dec 23, 2012 | 12:56 PM
richard88vette
5th Gear
Thanks for that - no risk of galvanic corrosion between the stainless and alloy then?
Old Dec 23, 2012 | 05:56 PM
black88z51's Avatar
black88z51
See for yourself:
I used ss bolts on a set of rims I had refinished and never had a problem.
If your still curious then use a rubber washer between the two.
Old Dec 23, 2012 | 08:02 PM
richard88vette
5th Gear
Looks neat. Thanks for the steer.
To Replace 1988 centre cap bolt
