1988 Brake Problem
Old Jun 10, 2002 | 10:01 PM
mjharris88's Avatar
mjharris88
Cruising
Default 1988 Brake Problem
My 88 brakes are acting very strange. When I first start the car and back out the pedal travel nearly to the floor but the brake light does not come on. If at a light and I apply pressure the pedal gradually goes down. I have checked all 4 calipers since manual states this indicates a leak in the line however I see no leaks and I am not loosing fluid from the master cylinder. I have bled the brakes in the proper order but the problem continues. My question to you guys is do you think a master cylinder could cause these symptoms. Thanks in advance.
Old Jun 10, 2002 | 10:08 PM
PeteL's Avatar
PeteL
From: And on the fifth day, subpoenas were served to Obama senior staff
Default Re: 1988 Brake Problem (mjharris88)
Sorry, that sounds like fairly classic failure of the master cylinder.
Old Jun 11, 2002 | 08:51 PM
mjharris88's Avatar
mjharris88
Cruising
Default Re: 1988 Brake Problem (PeteL)
thanks alot for the advice
To 1988 Brake Problem
