Installed K&N filter--problems
Old Dec 28, 2012 | 03:21 PM
vettenutchas's Avatar
vettenutchas
Default Installed K&N filter--problems
I installed a K&N filter in my 94 and now I have an intermittent engine problem! Sometimes I have what feels like a miss or shutter in the engine when accelerating from an idle. Does not happen all the time. No engine light yet. Occasionally it will stall when I shift from reverse to drive. Starts right back up. Any one have this problem after installing a Brand New K&N filter? Thanks for any help you can give.https://www.corvetteforum.com/forums...ilies/ack2.gif
Old Dec 28, 2012 | 03:51 PM
Docderek05's Avatar
Docderek05
Have you taken your maf sensor apart and looked at the wires? do they have gunk on them from the oil of the k&N? little blobs, typically, takes nothing to screw up the sensor,..so they have to be clean. do NOT touch the wires,..unless you want to buy a new MAF. that is what happened to mine, I also have a 94 lt1, and I got some TB cleaner, and sprayed the sensor wires, very well, cleaning them, let them dry..and reinstalled, problem went away, and I went back to my Stock Paper filter, cause I found no seat of the pants diff with the 100 dollar K&N. also, check the seal of your stock filterbox to be sure it is sealed well..the K&N..is a bit sloppy in there, its a bit too big, and you need to insure you have a good seal. Best, Derek
Old Dec 28, 2012 | 03:58 PM
FOURSPEEDVETTE's Avatar
FOURSPEEDVETTE
Funny thing is I was just reading some information about K&N filters and some of the consumer reports stated that others were having this same problem. I wonder what's behind this.
Old Dec 28, 2012 | 04:10 PM
nutz4c4's Avatar
nutz4c4
Over oiling the filter....
Old Dec 28, 2012 | 04:31 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
And to be fair, this has nothing to do with it being a K&N filter.
Any of the other brands that require a filter oil can possibly have the same issue.
Quite a few users put way too much oil on them.
If that oil gets on the MAF sensor wires, it will cause problems no mater who's filter your using.
To properly oil one of these filters takes a little bit of practice.
You put a small amount of oil on the filter pleats and then allow the oil to "wick" through until covered.
If you pour (or spray) the oil on the pleats until they are covered, you will have too much oil on the filter and it will get sucked into the MAF sensor and cause issues.
Old Dec 28, 2012 | 04:43 PM
FOURSPEEDVETTE
Now it makes sense.
Old Dec 28, 2012 | 06:33 PM
gerardvg's Avatar
gerardvg
Missing or stuttering engine on acceleration is usually a plug fouling or an intermittent injector problem. Check your ignition leads resistance and plugs for fowling or cracked insulators, maybe replace the plugs it they have not been replaced in a while. Then maybe look at the dreaded four letter word item ..... OPTI
Good luck hopefully just a fouled plug
Old Dec 28, 2012 | 06:57 PM
Red Dwarf's Avatar
Red Dwarf
Check for codes..may be something in there?
Old Dec 29, 2012 | 09:54 AM
WW7's Avatar
WW7
...................Bingo..................
Old Dec 29, 2012 | 10:00 AM
vettenutchas
Filter is brand new--I did not oil it--installed it as it came from factory!
Old Dec 29, 2012 | 11:48 AM
anciano's Avatar
anciano
Exactly. I don't know why anyone thinks that fine oil mist won't be pulled out of fabric by a high-speed air column passing through, no matter how lightly oiled. If the FACTORY can't get the oiling right, how can somebody in his garage be expected to? Dump the K&N.
I have to give K&N credit, though, for the best marketing program ever. They convince people to buy a filter for three times the cost of an OEM paper filter (which was good enough for the engineers that designed the car) with the argument that it saves money in the long run because it's reusable. Sure it is -- IF 1) you still have the car 90,000 miles later (replace the OEM filter with a K&N at the 30K scheduled replacement interval at a cost of $75 instead of $25 paper filters at 30K, 60K and 90K); and 2) you don't buy K&N's own proprietary cleaning solution and oil -- which of course you have to do.
Add in the cost of MAF sensor cleaning spray and you have the strangest calculation for saving money that I ever heard.
And of course there's the PITA process of cleaning and re-oiling to just the proper amount to not foul the MAF -- which may in fact not be possible as vettenuchas points out.
I wonder if you can dose the K&N with snake oil insead of their own product and get the same fabulous result.
Old Dec 29, 2012 | 12:11 PM
BGZQ8's Avatar
BGZQ8
Plus you forgot to add that it lets most of the dust , dirt and grime go thru it.
Old Dec 29, 2012 | 01:18 PM
anciano's Avatar
anciano
Yes, independent tests have showed that, too, but I just stuck to the economics of the thing because I didn't think the faithful would question K&N's bogus claims with respect to effectiveness of filtration. After all, the company calls it the "world's best filter." Isn't that enough?
Old Dec 30, 2012 | 09:24 PM
Docderek05's Avatar
Docderek05
Getting away from the Op's original trouble..
but I understand both sides of the fence w the K&N, or any oiled cotton filter.
the issue is whether his MAF is fouled, and that is causing his sudden onset problem
following the change to the oiled filter. I would try going back to a stock filter, cleaning the MAF's wires, D/C the neg battery cable, checking his MAF three wire connector, gently cleaning the connector with wooden toothpick,on the female ends...and using a very light coat of dielectric grease on the connector, reconnect the battery, give the computer some idle time to reset parameters, then see if the problem persists, and go on to other diagnostics, from that point.
Old Dec 31, 2012 | 10:27 AM
rad928music's Avatar
rad928music
You are mostly correct.
I worked at a company that makes and made High Performance air filters for C4, C5 &C6.
I got to know a old guy that did development for over 30 years and HE told me they tried the K&N against there products and that cause allot a problems with some of there test fleet vehicles from Oil collecting on Inlet sensors.
I use one In my 86 put I spread it evenly and coat it just enough.
It works great in my Pontiac 400 engine because its Carbed and has no Computer, and no inlet sensors, in fact it slightly lubricates the carb and keeps moisture out.
Old Dec 31, 2012 | 02:09 PM
radar502's Avatar
radar502
Default Looking NOS rubber Bushing 96 ..HELP
Had to ask anybody know were to get rubber bushing trailing arms etc. For my 96 ..thanks
Old Dec 31, 2012 | 02:11 PM
radar502's Avatar
radar502
Sorry ,I hit wrong key..But I do have K&N works great...
To Installed K&N filter--problems
