Transmission Question
Old Dec 28, 2012 | 08:35 PM
1993C4LT1's Avatar
1993C4LT1
Default Transmission Question
Hey guys. I haven't driven my '93 in 1 week. The temps here are 39. I let the car warm up to 130 and oil was at 80 degrees. On my way to my cousin's, I hit the pedal and it felt like always (fast). After that it was at 2000 rpm, doing 20 mph. It takes a lot of gas to past 20 or 25 mph. Any ideas on what's going on the tranny?
It's an automatic.
Edit- It moves in drive and reverse.
Old Dec 28, 2012 | 08:54 PM
NuckinFutz93's Avatar
NuckinFutz93
It could be time for a drain and fill with a new filter. DON'T do a flush and fill, It can break nasty stuff loose and cause other things to start going bad. Flush and fill is one of the big time killers of high mileage autos (70k+)
Old Dec 28, 2012 | 08:58 PM
1993C4LT1's Avatar
1993C4LT1
Thanks nuckinfutz93, I sure hope that is case.
Old Dec 28, 2012 | 09:29 PM
383vett's Avatar
383vett
Not sure what is wrong with the tranny. Check the fluid level for starters. You might want to heat up the motor oil another 50 degrees or so before really hitting the go pedal. 80 degrees isn't warm enough for the oil to flow and throughly lubricate as designed.
Old Dec 28, 2012 | 09:42 PM
1993C4LT1's Avatar
1993C4LT1
Checked the tranny fluid in my drive way(flat), it was in the cold area.
Old Dec 29, 2012 | 12:12 PM
1993C4LT1's Avatar
1993C4LT1
Let the car warm up around 10 minutes, trany was shifting great. Car was acclerating the way it's supposed to. I was being too paranoid.
Old Dec 29, 2012 | 12:29 PM
Kmcoldcars's Avatar
Kmcoldcars
I would think you may have a problem. I drive my 1992 automatic here in Washington State in the winter with the temps around 20 degrees. I start the car and drive it with no problems and no warmup.
Old Dec 29, 2012 | 01:15 PM
1993C4LT1's Avatar
1993C4LT1
I might. Yesterday, I let it warm up for not too long. Checked the fluid at night, couldn't see that good. So it looked like the fluid was low, checked this morning and it was fine. No burnt smell either.
Old Dec 29, 2012 | 02:36 PM
NuckinFutz93
I still say a drain and fill wouldn't hurt. You could have cold clogs in the filter.
Old Dec 29, 2012 | 06:11 PM
Old Ben's Avatar
Old Ben
2017 C6 of Year Finalist
No problems on my 92 automatic with morning temps in the low 30s and only a couple minutes of warm up. It could have just had a bug that morning.
To Transmission Question
