Interior electrical issue light timer
Old Dec 29, 2012 | 01:35 PM
Kahl's Avatar
Kahl
7th Gear
Default Interior electrical issue light timer
Hi - I am having a problem with the electrical system on my 1988 Convertible. I had a drain on the battery that I traced back to the interior light timer, which I replaced. The new one worked for a day or so, but soon the lights didn't work when I opened the doors, and the rear hatch no longer will work. So I thought I received a faulty replacement, so I installed another one, and it worked for a day. I am at a lose, anyone every experience this issue before? Looking at the wiring diagram I was wondering if I could have a bad ground. It seems to interfere with the chimes, (they only chime twice when the doors are open). I could sure use a little guidance / suggestions!
Old Dec 29, 2012 | 10:37 PM
Cliff Harris's Avatar
Cliff Harris
Check the switches in the doors. They very often stick in the pushed-in position.
The hatch release also goes through the timer module. The hatch will not open with the doors closed. I don't know why they did this since you can't get to the hatch release switch anyway with the door closed.
The SECURITY light should come on when you open a door. That will tell you if the switch is working.
The chime only works if the key is in the ignition when you open a door. It will also chime with the headlights/parking lights on and ignition off. It will chime if you don't have the seatbelt fastened when you start the car.
Old Dec 29, 2012 | 10:47 PM
NuckinFutz93's Avatar
NuckinFutz93
So your hatch don't open if you accidently hit the hatch button at a red light or something.
Old Dec 29, 2012 | 10:50 PM
Kahl's Avatar
Kahl
7th Gear
Hey Cliff thanks for replying. I pulled both switches out today, cleaned and tested the wiring, both seem to work as they should, I even swapped them. I did however notice that the light green wire coming off the chime is not working, that is the wire that controls the open door alarm. The book states there is a ground under the dash, but I can't see it under there. Any idea where they put the darn thing? I have been chasing this issue for over a month, and thought I solved it on more then one occasion. It is like chasing a ghost.
To Interior electrical issue light timer
