LSx swap question...
It's just a thought I had while driving today...wouldn't that be a lot easier to get the C5/C6 instrument cluster working rather than piggy-back onto the stock ECM to run the C4 cluster?
All I'm interested in is the drivers cluster...if it is the same general size as the C4 cluster it should be an easy swap.
Although I "technically" don't need it in a race car, I LIKE it and use it to the maximum when I'm on track.
And I don't flat spot race tires...which is a HUGE plus.
There was a write up about fixing the late tachs with a resistor. I think if this resistor is taken out or replaced with a different value the tach could be "dialed" in. My oil is pegged but I believe that to be a wiring mistake on my part. I am running all the same old wiring and the oil sender from My L98 with an adapter it should work just as it used to. The Temp reads a little high but again I think this has always been an issue, I can now see because I have a "smart" PCM.
As simple as a reistor, or jumper to fool the EBCM into thinking the ASR setup is still installed. Since ABS and ASR are so intimately linked, it would be ashame to lose ABS just because the crap ASR system is removed. There are some threads here about removing the ASR, I just need to find time to go through the EBCM schematic in the FSM and also pull the codes to see if I can get the ABS light off..
Turner Motorsports has one they use from an M3...http://www.turnermotorsport.com/p-37...g-harness.aspx
I like that it is a true 4-channel ABS system, not 3-channel like most OEM's are set up with (2-channels front, 1-channel rear).
Could get a bit pricey...but I have some BMW connections and might be able to seriously undercut their prices. That, and I think sourcing the pump and other components besides the brain from a wrecked car could save a bunch as well. The entire system from them (harness, controller, pump, sensors) with new parts is close to $12k...I think I could cut that in half easy.
Epic Motorsports also sell a similar harness http://store.bimmerworld.com/epic-mo...tem-p1691.aspx for WAY less money...over $1200 less than Turner's.
The 3 codes were a bad Right Front Sensor, TPS failure, and Data Link failure. I cleared them all and only the RF sensor returned but since I didn't hook up the LS TPS to the C4, I expect it will return once the car moves. (The RF sensor is checked at key-on, the TPS checked at drive time)
If the Data Link error doesn't reoccur (I don't expect it to since I'm still running both LT1 ECM and CCM) I believe all that needs done is to get a TPS signal into the EBCM. This may be more of a issue for me since I retained the DBW LS3/L99 throttle-body and I've failed in most every other digital sensor connection to both the LS3 ECM and the C4. A standard DBC TPS might be easier by I can't comment.
But if you're not running the stock ECM/CCM, there may be additional issues (like the Data Link) that will keep the stock ABS system from functioning.
With a ZR1 harness in the car, and using an LT1 ECM trying to drive the dash & other systems...I might be asking for many nights of frustration.
And I plan to go drive by cable...it is a race car, so the less electronics I throw at it the better reliability I'll have.
I was talking to a Corvette shop owner who is a good friend...his suggestion was to scrap the LS computer all together and get a F.A.S.T. system.
I hadn't considered that until now, but think I might at least investigate it. They have a VSS output option available...might be a better solution in the long run for me.
I need to dig into the manuals...I ordered the '92 Shop Service Manuals for the ZR1. Waiting for them to ship now...this car had ASR on it as well. For all the hassle of getting the OEM systems to talk to each other again...it might be easier to get an ECM that is a little more flexible.
Since I haven't really started yet...all options are open.
