Bought a base '96 convertible in August for $12,500 w/56,000 miles. Within two weeks had to put on a starter. After another month picked up something in a rear tire, two new tires. Another month goes by and had to replace the EGR valve. Had the exhaust modified (self inflicted). Now the water pump leaked, thru the PO335 & 336 codes. Having water pump and Opti spark replaced. Still needs some other items fixed.
Welcome to the wonderful world of vette ownership$$$! You never know what you are getting into! Mine has 106,000 and runs great! Some parts last longer than others!
Why is your name 90_vette when you have a 96? Do you also own a 90?
Can't really count the tires. Why did you have to change the EGR, emissions? It doen't sound to out of line so far for a 17 year old car. Often time the low mileage cars will have more problems than the ones driven regularly.
C4 of Year Winner (appearance mods) 2019
It's a 17 year old car. What exactly were you expecting?
It's car period.They need maintenance and care.I have a non profit that takes unwanted C4s in. Let me know if you want someone to adopt.
BTW it doesn't sound all that bad. Keep your head up.
Now I am starting to panic. I have a bank check ready to hand over to a guy with a 95 with 29,000 miles. Car looks in showroom condition.
i would have never guessed the optispark was trashed (broken seals, water intrusion, rusted) on the immaculate 93 vert 6spd w/ 26k miles I bought in the year 2000.
It was.
Of course 95-96 has the vented optispark, so perhaps its still good.
"Of course 95-96 has the vented optispark, so perhaps its still good." I wouldn't count on it! You can vent out the moisture, but you can't get the fog off of the photo cells from the antifreeze.
I know what you're going through....Sounds like the repair list for my LT4 except I don't have the EGR! Did rear axle stub & seals, all 'U'-joints (twice) rear wheel bearings, all four O2 sensors, wires & plugs, played the Opti game when the water pump pee'd on it. But HEY! It's like a new car now. It's all fixed!
My wife stopped dosing my scrambled eggs with Dawn dish detergent, because of my foul mouth, and we are now enjoying our car.
I picked up a 1988 4+3 with 141000 miles in august and have sense replaced the water pump, timing chain, clutch slave cylinder,
Clutch master, and the ecm, have small oil leak at distributor or oil pressure switch, now that winter is here no power brakes intell it gets warned up, maybe -2 is a little cold
...that's what owning a Corvette has to be or you'll go crazy agonizing over the money you're putting into it. I bought my '89 cheap (I thought): $3,500. Then promptly put over $11K into it, But it's worth it to me. I love the car!
