A/C questions
Old Jun 12, 2002 | 06:05 PM
Bill94LT1's Avatar
Bill94LT1
Default A/C questions
What year did the a/c freon change from R-12 to R-134 in the Vettes? If low
on freon, does the system need to be evacuated before recharging? Where is the low pressure valve for refilling located? Is it worth doing myself, or should I head off to a mechanic? HELP! :( :cry :crazy:
Old Jun 12, 2002 | 06:26 PM
JonM's Avatar
JonM
Default Re: A/C questions (Bill94LT1)
R134a is in all automobiles manufactured after 1994, some during 1993. It should tell you on the compressor what you have. There is only one size low pressure valve on all cars. You can buy a kit at a parts store. My only thought would be, its supposed to be a closed system, where did the coolent go? You may have a leak....Try this site for FAQ's http://www.id-usa.com/spkits.htm
