1989 6-Spd
Old Jan 27, 2013 | 08:51 AM
mroxford's Avatar
mroxford
Default 1989 6-Spd
Test driving a 89 coupe this morning for the second time. The first drive I noticed a slight whine in first gear with all the other gears sounding smooth. Is this normal?
Old Jan 27, 2013 | 09:26 AM
Txbobcat's Avatar
Txbobcat
That would not be normal in my 92. Is it cold? fluid level right?
Old Jan 27, 2013 | 09:53 AM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
Normal. Screaming, howling, clunking, chunking, or talking in tongues would be cause for some concern.
Old Jan 27, 2013 | 02:37 PM
lozer's Avatar
lozer
concur. not normal and the zf6 is not a cheap rebuild or replace either.
Old Jan 27, 2013 | 05:02 PM
zr1fred's Avatar
zr1fred
I had misread the post above me, so no, I don't think that a slight whine is uncommon, I have it on most of mine. The earlier ZF's were noiser than the later ones. You might check with the guys over in the ZR-1 section. They are VERY expensive to rebuild though.
Old Jan 27, 2013 | 05:18 PM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
First 3 years had straight-cut gears. Later years had more of an angle cut...and are quieter.
If you're talking about a soft whine that would be hard to hear over low radio noise, I think that's normal. If it's as loud as tire noise (or louder), I'd be more concerned.
I can sometimes hear the slightest whine even on the hwy in other gears too. Very faint.
Old Jan 27, 2013 | 05:34 PM
Leftoverture's Avatar
Leftoverture
Yes, the early zf's tend to be loud. But they are very stout, too. It's hard for any of us on here to be able to tell you if what you're hearing is normal, though, without having heard it ourselves. See if you can find a knowledgeable local forum member or mechanic if you are not sure about it.
Old Jan 27, 2013 | 05:59 PM
mrmtrtrnd's Avatar
mrmtrtrnd
My 93 ZF makes a little noise in first but I can't tell you if that 89 is abnormal or not without hearing it. If you have doubts about it have it checked out before you buy it.
Old Jan 27, 2013 | 06:27 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
Watch the beginning of this video...
When I FIRST pull out of my pit-spot, you can hear what I consider to be normal 1st gear whine in a ZF6.
Also at 0:30 when I downshift to first and mat it...
FYI, this is an earlier/"Black tag" ZF6 which would be the noisiest variety.
Old Jan 27, 2013 | 07:28 PM
mrmtrtrnd's Avatar
mrmtrtrnd
I hope that video helped morxford but either way I enjoyed watching it, very cool
Old Jan 29, 2013 | 02:22 PM
89 Vett's Avatar
89 Vett
Looks like you're using a GoPro? You might look into a Contour. The lens is adjustable to compensate for the mount angle.
My 89 whines the same way as the video indicates after a fresh rebuild.
To 1989 6-Spd
