Pulled codes today ! Need help
Old Feb 1, 2013 | 11:01 AM
Mohammed_z's Avatar
Mohammed_z
Default Pulled codes today ! Need help
I had these six codes pulled from the ac display.
I couldn't find a reference for the codes here !! what are they ?
car is a '94
64 , 139 , 97 , 198 , 176 , 02.
Old Feb 1, 2013 | 12:48 PM
QCVette's Avatar
QCVette
Active Streak: 90 Days
Here is a site that lists them.
http://tech.corvettecentral.com/2011...trouble-codes/
It did not have all of the ones you listed though.
I checked in my '94 service manual and it matches to the web site. The manual does not list the codes for 02, 139, 176, or 198.
I thought the codes show up in the speedometer display not the AC display. Maybe I am looking at something else.
I also checked the AC sections of the service manual. The automatic digital controller has DTC codes, but it only has DTC's 00 through 10. The 02 is for a Temperature Door Motor Circuit Fault.
Good luck.
Old Feb 1, 2013 | 04:00 PM
Mohammed_z's Avatar
Mohammed_z
Good luck.
ok , what's the difference between the codes on the ac display and the codes on speedo display ?
what do you mean by DTC ?
Old Feb 1, 2013 | 04:37 PM
QCVette's Avatar
QCVette
The AC codes are for the AC system.
The speedometer codes are for the engine and body.
DTC is Diagnostic Trouble Codes.
Old Feb 1, 2013 | 05:38 PM
vetteoz's Avatar
vetteoz
Read
You need to be aware of what module you are reading the codes from,
the codes displayed in the speedo are in different "modules" depending on what system PCM /CCM/ ABS ,is being displayed.
To Pulled codes today ! Need help
