Audio system
Old Feb 11, 2013 | 05:08 AM
ricasso's Avatar
ricasso
Default Audio system
I've just been told that the Bose in my '94 coupe is a DIN and a half? I thought it was double DIN! Im wanting to fit a modern Alpine CDE-W235BT CD Tuner with Parrot Bluetooth unit (double DIN) and matching speakers (with new wiring of course!) does anyone know if it would fit straight in or would it need some "surgery"
Old Feb 11, 2013 | 06:12 AM
AirForceOne!'s Avatar
AirForceOne!
It fit perfectly in my 90 with no mods! Don't know how much different your 94 interior is?
Old Feb 11, 2013 | 06:24 AM
ricasso's Avatar
ricasso
Very very similar! mines slightly more "recessed" than yours especially on the lower edge, not flush like yours, but I cant imagine the actual unit apature would be any different, yours does look good though!
Old Feb 11, 2013 | 06:29 AM
AirForceOne!
I'm pretty sure it will fit. I measured mine before I had the stereo shop put it in. It's a great stereo!
Old Feb 11, 2013 | 08:07 AM
Goldcylon's Avatar
Goldcylon
All C4s from MY90-MY96 are a Double DIN. Depending how deep your system is you will need to cut the back plastic channel that the center screw from the old BOSE unit rests on but thats no big deal for a dremmel. Go ahead and order the Metra install kit which is pretty cheap. It will show a pocket for a single DIN radio set up however you will throw that away and only need the side mounting brackets. Amazon.com is normally the cheapest.
Heres how my AVIC Pioneer system looks GC
Old Feb 11, 2013 | 08:42 AM
ricasso's Avatar
ricasso
Well, Ive just been out and bought one! I got a speaker system as well and about 10 metre's of speaker cable so now Im ready to go! I'll be hard wiring it in, I always find that it gives less "noise" that way.
just one question for Air Force, did the stock antenna lead fit or did you have to modify in any way.
Old Feb 11, 2013 | 09:31 AM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
You will very likely need an adapter.
The factory GM antenna connectors are a different size than any aftermarket radio I've ever seen.
Pretty common adapter though, and can be found anywhere that sells audio stuff. A Google search for "GM Antenna Adapter" will find what your looking for.
Note:
You will also need a much longer antenna cable. Your factory antenna is connected to the actual radio receiver located in the storage bin behind the passenger seat.
Your new aftermarket unit will be one self contained unit going into the dash.
So, you'll need a cable long enough to reach up there.
Old Feb 11, 2013 | 09:49 AM
AirForceOne!
I had a stereo shop pt it in, so I would listen to what RollaMo-LT4 listed.
Old Feb 11, 2013 | 10:26 AM
GKK's Avatar
GKK
Here are the Instructions to upgrade the C4 Audio system.
http://forums.corvetteforum.com/audi...audio-faq.html
You will also, have to install two 1k ohm 1/2 watt resistors, (from Radio Shack) in the stock harness or an annoying blinking "SYS" will display in the LCD panel. Just follow the diagram in these instructions. http://www.corvetteforum.net/c4/dave8476/index4.shtml
Old Feb 11, 2013 | 11:33 AM
ricasso's Avatar
ricasso
would this be necessary on my '94, on the link it it only covers up to the '93 model.
Old Feb 11, 2013 | 01:32 PM
GKK's Avatar
GKK
I'm not sure but, after the install if the "SYS" light displays and then disappears every 10 seconds or so, you'll know what the problem is.
Old Feb 11, 2013 | 01:39 PM
AirForceOne!
I think you should be ok, the stereo guy's that put mine in never put any of the resistors in and I have never had an issue in almost a year! I think they used a GM adaptor plug and it worked fine.
I did show them the service bulletin and they said they have installed hundreds of vettes and never had an issue, but they said if I did they would fix it for free!
Old May 1, 2013 | 10:16 PM
Squawk's Avatar
Squawk
Cruising
Great look.
Thinking of getting one for my 94 vert. What was the speaker set up? did you use the bose and amp or change them out?
Old May 2, 2013 | 01:55 PM
AirForceOne!
Alpine all the way around, no amps.
Old May 2, 2013 | 04:34 PM
92polo's Avatar
92polo
I purchased a pioneer unit for $450.00 and had the local stereo shop do the install. They removed all of the Bose equipment, installed new pioneer unit, hooked up the blue tooth and rear camera, new speakers and new wiring for $425.00.
Old May 3, 2013 | 06:55 PM
AirForceOne!
Wow that's a good deal!
To Audio system
