Cooling system hoses
Old Feb 13, 2013 | 09:20 AM
lvm94's Avatar
lvm94
Default Cooling system hoses
Have a 94 vert and have decided to replace all the hoses while its down for the winter. I know they sell T.B. bypass hose kits but I would rather clean up this area when I change the hoses and get rid of the tees. Do previous or newer cars have the same hose configuration or can I use a different years hoses to accomplish this?
Appreciate any help
larry
Old Feb 13, 2013 | 11:09 AM
mxw128's Avatar
mxw128
I had the same question but hadn't gotten around to researching it yet... I thought I had heard or read somewhere that 96 hoses didn' thave that "T", but I don't recall... curious to get the answer...
I did find this here where somebody did use a 96 upper hose, at least on one side:
http://forums.corvetteforum.com/c4-t...pples-too.html
Old Feb 14, 2013 | 08:29 AM
dizwiz24's Avatar
dizwiz24
Good idea that you are replacing your hoses. In 04, my upper radiator hose got a leak spraying coolant all over my outside front tire.
Luck would have it I was racing at nelson ledges and spun out entering turn 1 at 90 mph. Luckily the car stayed on the track
Yes, you don't need the tee and bypass hose. I got rid of mine. I think 96 was whenn they cleaned it all up.
Old Feb 14, 2013 | 08:42 AM
shakedown067's Avatar
shakedown067
St. Jude Donor '12-'13
Yep, the 96 is a nice and simple job. If I remember right, I was able to remove the driver's side altogether and just plump the passenger side hose right in. I don't remember having to use an adapter, but it's been quite a long time since I've done it.
I also really like the samco silicone hoses. It's a nice piece of mind over just stock rubber.
Old Feb 14, 2013 | 09:51 AM
mxw128's Avatar
mxw128
So did 96 delete the tb coolant path altogether, or just plumb it in from someplace else?
(Btw, like the tires... Which ones are you running?)
Old Feb 14, 2013 | 10:05 AM
shakedown067
It certainly went through the TB, but it was SUPER easy to bypass. That's all I really remember. If I had it at work, I'd snap a few pics. I'd say I'd do it tonight, but it'll probably be dark by the time I get home.
The tires are vredestein ultrac sessanta, 315/35/17. And I absolutely love them.
To Cooling system hoses
