C5 rotors on C4
Old Jun 14, 2002 | 10:54 PM
vettelover's Avatar
vettelover
Default C5 rotors on C4
Hi guys
Can any one tell me if 13" C5 rotors will bolt on a 87 coupe .
I have bought GS calipers really cheap , and a friend of mine is selling his front C5 rotors at a bargin price .
THANKS IN ADVANCE
Vettelover :seeya
Old Jun 15, 2002 | 04:15 AM
vettelover's Avatar
vettelover
Default Re: C5 rotors on C4 (vettelover)
Can anyone help at all ?
REGARDS
Vettelover
Old Jun 15, 2002 | 04:36 AM
shamvette's Avatar
shamvette
I can tell you that the Baer Eradispeed rotors, which are 12 3/4", will work. I think the 13" C5 rotors will also work, but in order to do this mod however, a bracket is required which is used to mount the C5 calipers to the knuckle assembly. It also may be necessary to move to a 17" rim for clearance. There is quite a bit of archived information on this topic in the C4 Technical Archived section. If you search on "Rotors" in the Archived data, you will find quite a few posts. Hope that helps.
Old Jun 15, 2002 | 06:33 AM
vettelover's Avatar
vettelover
Default Re: C5 rotors on C4 (shamvette)
Hi Shamvette
Thank you for your responce , the reason i ask this question is because i have GS calipers not C5 calipers and i didnt know whether the C5 rotors are compatible .
Thank you .
To C5 rotors on C4
