Alignment
Old Feb 23, 2013 | 03:18 PM
Alan777's Avatar
Alan777
Default Alignment
I drive a 1991 Z07, and I need to get it aligned. I run ZR-1 replicas with 315's in the back, and I wanted to run a little bit of camber the whole way around to bring the tops of the 315's in a bit. How much camber can I run on a stock suspension without any significant wear/handling issues? Are there any aftermarket alignment specs you guys have done and been happy with? Car is street driven so i dont wan't to go crazy, just looking for something "better" while I'm getting it aligned anyways.
Old Feb 23, 2013 | 04:57 PM
Larry/car's Avatar
Larry/car
There might be a service directive on alternate settings. I personally don't experiment with suspension settings.
Old Feb 23, 2013 | 06:41 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Old Feb 23, 2013 | 08:35 PM
383vett's Avatar
383vett
Running excessive negative camber will not give you handling problems. It'll just wear the insides of your tires quickly. You'll be able to corner quicker.
Old Feb 23, 2013 | 10:49 PM
93Rubie's Avatar
93Rubie
Negative Camber=
Old Feb 24, 2013 | 05:34 PM
Alan777's Avatar
Alan777
Definitely, however I'm trying to find a happy medium since I put a lot of miles on the car.
Thanks PLRX, I think I'll run the advanced street setup and see how it is. I have really bad toe out on my left front for some reason so anything's better than it is now.
Old Feb 24, 2013 | 05:41 PM
PLRX's Avatar
PLRX
2017 C4 of Year
Old Feb 24, 2013 | 07:54 PM
93Rubie's Avatar
93Rubie
If your stock now, expect a noticeable handing difference in the advance street setup. I know I did.
To Alignment
