EGR error disappears
Right after I brought her home I took her to a local business where they would let me put her on the rack and inspect her closely. At that time I used a 3-part fuel injector cleaner http://www.expressoil.com/services/fuel-systems/.
All of the the fuel I have used since I got her back from her former state has been non-ethanol 93 octane.
A few weeks ago I ordered my first batch of parts from Ecklers, and included a EGR sensor in that order after having read to start there on clearing up the EGR Circuit error code (32).
Since I placed that order with Ecklers the error code has not returned. I first noticed that instead of the "Service Engine Soon" light coming on and staying on until I cut the ignition off, it would come on and then five or ten minutes later be back off. Now it seems to just stay off, like its fixed.
So is it possible that the use of quality, non-ethanol gasoline could clear up a EGR code, or is the fuel system cleaner I used more likely the cause?
What do you guys use for fuel in your C4s? Is High Octane fuel good enough, or does it need to be non-ethanol?
Thanks for the input!
Derek
The EGR doesn't function all the time. On my '88 the EGR was bad, but the light would only come on after about 10 miles at highway cruising speed. In town it frequently would not turn on.
Good luck.
The EGR code is because the ECM doesn't see the EGR working when it turns it on because;
EGR is not actually working
or the switch which tells the ECM the EGR is working is faulty
Could also be a problem with a bad ( intermittent ) wire connection to the terminal on switch (common )
When I looked into it, the egr code on my '88 was set when that insulated tube at the back of the manifold has a sensor. When the egr is supposed to be functioning, that sensor should show that it is hot from the exhaust passing through it.
There are a few threads on here that say you can "fool" the computer to turn of the light by wiring a resistor into the sensor wiring so it thinks it is hot and it won't trip the code. I tried that a couple of ways, and couldn't get it to work. I finally broke down and just changed the EGR valve. That fixed mine. (Just a note: I tried one from a local parts store and it wouldn't hold a vacuum. I checked the second one before I left the store and it was bad too plus it was the wrong part for some other application in the correct box for what I needed. I got the original AC part and it worked fine.)
Good luck.
I am driving about 40 miles of interstate at normal highway speeds each way to & from my job. It's been about 2 weeks of driving it, about 20 hours of driving combined, without seeing the code again.
I think I'll just install that sensor I bought and forget about it if the error code does not return.
All I need to do is unhook the electrical plug and unscrew the sensor? When I install the new one should I use some anti-sieze or something on the threads of the sensor?
Appreciate you guys!
Derek
The valve will shut when accelerating or not on a steady cruise hence why it does not give a code in stop start driving with varying throttle positions.
The EGR code will appear after a steady cruise of 10-20 mins if the sensor does not close with the temperature.
Check the EGR tubes are not blocked for later 86 early c4 had the egr bypass in the inlet manifold.
Check the valve actually works, you can do that by sucking on the vacuum hose to the valve and confirm it rises and drops again. Note if it sticks you will get hard starting.....
There is a vacuum solenoid valve that the ECM opperates it has the vacuum hose from the TPI inlet manifold going to it and the other hose on the valve goes to the EGR valve under the tpi manifold but you can see the EGR valve by looking between the runners.
Good luck should be a simple fix
It would go out and stay off (self clear) until I repeated the above condition.
I replaced the EGR temp sensor that's mounted in the exhaust tube from #8 to the intake.
No more code.
No more code.
www.rwva.org
