Adios C4 track car...
1. The LT4 is capable of RELIABLY making 500hp. The engine was a 383 LT4 with an Eagle rotating assy, stock heads (with some basic work done), a Quick Fuel R/R carb, crank trigger MSD ignition system with Digital 7 box and Pro Power II coil, Meziere electric water pump, and some other goodies. It showed right around 500hp on the dyno with a conservative tune. It got pushed harder than about 99.999% of the Corvettes in the World, saw a LOT of RPM and simply put, it just didn't quit.
2. C4 Corvette brakes... well... suck. If you are going to be hurling yourself down a track at ludicrous speed it is a good idea to be able to stop at the end of a long straight. Doing this even with J55 calipers with stainless pistons and lines as well as the best pads and rotors out there has a pucker factor that is off the charts. Do yourself a favor, spend a little $$ and go at LEAST with a Wilwood SL6 setup. It's relatively cheap, easy to maintain, and actually stops the car consistently. While we're on it... be sure to add some brake cooling.
3. The C4 suspension was great... for its time. When compared to other cars of the era, the C4 handles like a champ. On paper, with the big skid pad numbers, it looks like it compares to the modern cars very favorably. Unfortunately, the real World has a few more factors. The C4 suspension geometry doesn't compare favorably to the later generation Vettes. Everything from turn-in to stability to power down on exit is lacking in comparison. Don't get me wrong, you can get up on the wheel and make a C4 run right with the C5/C6 but what it takes white knuckles and a very finely calibrated *** to do in the C4 is done with ease in the later cars. It becomes VERY evident through high speed corners or in corners that aren't entirely smooth. The massive low end torque of the 383 kept me in line with the C5/C6 in terms of total lap times but even with big 315s all around they just walked away in corners and under braking. I will add that the braking loss was due to the overall stability of the car itself under the heavy front load, not the actual brakes. A big camber brace makes a HUGE amount of difference in the front end, especially under braking.
4. The factory cooling systems on the C4 are not adequate to withstand abuse. If you want to keep it reliable, you need no less than a power steering cooler as well as an external oil cooler. Ideally, I would have a diff cooler as well if you are running above stock power with big sticky tires. The water system itself is pretty decent. Even with the big 383 that put off a massive amount of heat, the stock system kept everything in check using distilled water AND WATER WETTER. The weak link in the system is the pump itself. The LTX driveshaft design does not seem to like sustained 6,500+ RPM. At that speed, even a slight cavitation makes the internals turn to shrapnel. With the Mezziere electric pump, all was well. If you do go with a mechanical make 100% sure that you are using a GMPP pump. The auto store pumps are not even remotely close to the same. They have less bearing packs, the internals are cheap stamped crap, and the shaft itself is some low grade steel.
5. The C4 is a very fun car to drive If your goal is to go feel like superman on a track, the C4 is a great car. It gives great feedback, is somewhat predictable, and responds well to pretty much all driver input. The most interesting part of the "feel" of the C4 is how well it responds to throttle input through corners. With even small inputs you can do everything from setting the nose on entry to making it rotate through the center. On the flip side of the response to inputs is the fact that if you get it wrong, it can go bad in a big hurry. It will reward you for doing it right, but is VERY unforgiving if you screw it up. If you are reactionary rather than proactive with your inputs, it is going to be a long day.
As I said at the beginning, as with any car, there is a near infinite list of things to be said but these were the first few that came to mind.
Most importantly, if you want to take a C4 to the track, you better have at least a decent amount of mechanical knowledge because something WILL break. Another in general comment is that if you plan on doing HPDE, build it how you want and go for it. Focus on reliability first and speed second. If you want to compete, build to a specific class. The biggest issue with this car is that it was impossible to class. With the modifications, it was put up against cars that it had absolutely no chance against. It was fun to drive, but in the end, I want to be competative.
Some HPDE fun:
I though about getting a C6Z but when it came down to it, there wasn't much to be gained considering the price swing. The only thing not easily overcome is the aluminum frame vs. the steel. The geometry is the same, the brakes aren't going to be stock either way so that's no big deal, you can easily make power out of the LS6, etc. My goal in building this car is reliability first, consistency second, and speed last. The C4 had speed but lacked severely on the other 2. With those goals in mind, the C5Z is every bit as (if not more) capable than the C6Z. Time has proven the LS6 to be about as bulletproof as it gets on a track. The LS7 doesn't seem to fare quite as well.
The C6Z might be faster in stock form simply because of the power but when it comes right down to it, the C5Z is every bit as good a track car, if not better. It also is a WAY easier car to class for competition.
The C5 will have some tricks thrown up it's sleeve...
I will certainly miss the "wow" factor of the C4. It was a safe bet that there wasn't going to be another like it at a track and I do have to admit that there was a certain amount of satisfaction in being able to pass C5s and C6s.
What's going to happen to that C4?
SKF racing hubs (and ARP studs) are no joke.
Compared to stock:
Not sure how much difference I could have made going that route but was always curious. The only reason I didn't was the simple fact that I didn't want to dump any more $$ in it knowing that it was pretty much stuck being a HPDE car because of the difficulty of getting it comfortably in a specific class.
My eventual plan is to go to a specific race platform instead of starting with something made for the street. I'm still learning these things and doing it on a thin dime and even less time it makes it a difficult jump into a full W2W situation. I am going to be limited on events as is and the schedule shrinks even farther if you take away those that don't allow open wheel.
I'm seriously considering going into something like a Radical when I finally do make the jump out of TT and into W2W. The Formula Fords are most definitely on the list as well. I think the deciding factor is going to be looking around to see what gives me the most schedule flexibility and opportunities to get on track. So far I have stuck to my long term plan pretty well. Right now, I'm planning on the C5 being about a 3 year run to get as much seat time and as much setup and tuning time as possible as well as getting myself where I need to be with licenses. From there... W2W.
Did you have any big offs? Any caught on camera? I learned a lot about cars I was in on trackdays by going beyond their limits
It does seem to make sense to go straight to a C5Z for trackdays rather than dump $$ into my C4. Would love some nice Wilwoods tho
