383 stroker
Old Mar 5, 2013 | 09:53 AM
John Byles's Avatar
John Byles
Cruising
Default 383 stroker
I'm doing a 383 stroker motor using an 89 L98 motor with aluminum heads. What cam can I use & can I use the ECM as is. I'm going to keep the stock compression ratio. Thanx in advance for your time
Old Mar 5, 2013 | 11:27 AM
GREGGPENN's Avatar
GREGGPENN
C4 of Year Winner (appearance mods) 2019
There are a lot of choices/options. too little info to reply.
Unless it's pretty radical, many/most reuse the stock ECM. Some do, however, upgrade from mid 80's to late 80s...or even MAP systems. (90-91).
Depends on your situation/goals.
Old Mar 5, 2013 | 05:50 PM
John Byles's Avatar
John Byles
Cruising
Thanx..jb
Old Mar 5, 2013 | 06:22 PM
vetteoz's Avatar
vetteoz
But it will probably require a new tune to suit the combo
I'm doing a 383
What cam can I use
What intake?
Old Mar 5, 2013 | 06:25 PM
John Byles's Avatar
John Byles
Cruising
stock intake & injectors..
Old Mar 5, 2013 | 09:43 PM
GREGGPENN's Avatar
GREGGPENN
pick a cam that matches the flow ability of your head. IOW, where lift matches the roll-off point of the intake port flow. Don't worry about cams that make power above 5k rpms. Duration @ .050 no bigger than 220...and maybe as little as 211-212.
Old Mar 5, 2013 | 09:50 PM
John Byles's Avatar
John Byles
Cruising
thanx...jb
Old Mar 5, 2013 | 10:30 PM
383vett's Avatar
383vett
What are you going to use the car for, just cruising, street/strip, autocross, the Texas mile? Are emissions a factor. What about fuel economy? After you answer these questions, you'll get better cam choice answers.
Old Mar 6, 2013 | 08:37 AM
John Byles's Avatar
John Byles
Cruising
using the motor in a street rod just for cruising. Fuel economy is a small issue but not critical. Thanx...jb
Old Mar 6, 2013 | 09:20 AM
GREGGPENN's Avatar
GREGGPENN
Since you're not jumping all over the details, should be assume it's stock heads, intake, etc...with only the addition of additional stroke? No head porting?
Don't make us TWIST your arm?
Old Mar 6, 2013 | 01:36 PM
383vett's Avatar
383vett
Crane hydraulic roller 222 230 worked for me.
Old Mar 6, 2013 | 01:39 PM
John Byles's Avatar
John Byles
Cruising
thats what I was looking at..in that area thanx...jb
Old Mar 6, 2013 | 01:41 PM
89 Vett's Avatar
89 Vett
If you're investing in a 383 you should open up the air flow to take advantage of your gains. One thing will lead to another and you'll likely find yourself porting and replacing many items.
If you're thinking a new chip is a big obstacle you'll find it is among the cheapest of the parts you'd end up buying.
Old Mar 7, 2013 | 07:00 AM
blackozvet's Avatar
blackozvet
I am doing a 383 also (engine still in a shipping container) I spoke to quite a few people and started a similiar thread, settled on a Howards retro roller kit (85 engine),
500/510 lift (or 530/540 with 1.6 rockers)
225/231 duration (at .050)
112 Lobe separation,
Cant tell you how it works yet, but thats the result of my homework on the subject,
but like the guys above have said, it depends a lot on the mods above the block.
Old Mar 7, 2013 | 08:20 AM
John Byles's Avatar
John Byles
Cruising
ok thanx...good info...JB
Old Mar 9, 2013 | 04:00 AM
classic8's Avatar
classic8
3rd Gear
Default What chip?
Blackozvet, what chip did u use? I have an 85 with very similar specs.
Old Mar 10, 2013 | 06:24 AM
blackozvet's Avatar
blackozvet
Howdy,
I have a Ed Wright Automotive Fastchip, he is one of the very few who do 85 computer chips, it made a big difference to mine, I will be sending it back soon to be reburnt due to the upgrades and new engine.
To 383 stroker
Old Mar 19, 2013 | 02:21 AM
classic8's Avatar
classic8
3rd Gear
Thanks for the info. Very helpful. What ***** did they require apart from cam details?
Old Mar 22, 2013 | 10:47 PM
blackozvet's Avatar
blackozvet
Look up the fastchip web site, he has a online order form you fill out.
Old Mar 23, 2013 | 10:02 PM
classic8's Avatar
classic8
3rd Gear
Cheers
