Vibration from back?
Balance, alignment, tires, rims, suspension bushings, ball joints, bent frame, rear gear, half shafts, ujoints, wheel bearings, etc... whew!! did I get it all?
a thorough inspection is in order, as well as a good haggling job for any and all work required before you buy it.
could be something simple, but then again maybe not
2 cents from a non-mechanic
Road force balance of rear tires
New shocks
Balanced the driveshaft and both half shafts
New u joints
It finally went away when I replaced the rear wheels
What made it tough to find was I had access to a hunter machine at work and the wheels and tires passed. I even spun the tires around on the rims IOT use the least amount of wieght
I even took the wheels / tires up the street to the nearest roadforce balancing place to have them done professionally (thought I may have been missing something) tech came out telling my he couldnt improve on how they were...
So long story short slight rim problems may cause a rear end vibration. Good news is once everything is perfect the vibration is GONE..
Good luck and happy hunting.
Mike
