oil
Old Mar 17, 2013 | 08:04 PM
86 dream's Avatar
86 dream
5th Gear
Default oil
is it ok to use 15/40 royal purple in my 86
Old Mar 17, 2013 | 08:06 PM
aklim's Avatar
aklim
Probably but what are you trying to achieve?
Old Mar 17, 2013 | 08:12 PM
speedycat3's Avatar
speedycat3
I believe the factory recommendation for 86 is 5W30 dino oil...
You will not hurt it going to full synthetic, but you probably want to stay with the recommended thickness for start up protection. It is probaby way overkill for your needs in a street driven car.
You might see increased leaks with Synthetic oil though; depending on your mileage and current oil leaks. Mobil 1 has a high mileage synthetic oil that is actualy meant to help with oil leaks in high mileage cars.
Old Mar 17, 2013 | 09:45 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
FYI; LORE, from the older days of synthetic oils. If you have leaks it will leak a like amount regardless of synthetic or regular type oil.
I agree that 15/40 is fine, but I would run something thinner for a variety of reasons including start-up flow and fuel economy.
Old Mar 17, 2013 | 09:54 PM
kimmer's Avatar
kimmer
C4 of the Year Finalist
I would not switch to synthetic oils on a high mileage car. Why change now.
Old Mar 17, 2013 | 09:58 PM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
For the same reasons that you'd start using synthetic with a new car. Not everyone buys new cars but still want the benefits (real and perceived) just like anyone else.
Old Mar 17, 2013 | 10:00 PM
kimmer's Avatar
kimmer
I believe I was asking the op.
Old Mar 17, 2013 | 10:02 PM
aboatguy's Avatar
aboatguy
15/40 is a might thick
Do you have oil pressure problems your trying to hide?
If not thinner is usually better (within reason)
Old Mar 17, 2013 | 11:06 PM
aklim's Avatar
aklim
Sounds about the same as the idea that by flushing a trans that hasn't been flushed it will break.
Old Mar 17, 2013 | 11:34 PM
speedycat3's Avatar
speedycat3
Not really... Synth oil does not break down as easily as dino oil and keeps its thickness; so thin synthetic oil tends to run a bit more.
I have used both for the longest time and in two particular cars that I bought uses but low mileage and changed to synthetic oil, both developed slow leaks right after the oil changes that were nbot present before. This is my actual experience, not hearsay. I did solve the leaks and all was good after that.
Old Mar 18, 2013 | 03:25 AM
Joe C's Avatar
Joe C
urban legend! show me one lab report analysis, done by an independent laboratory, or manufacturer, that's shows a transmission failure caused by a full fluid flush. BET YA CAN'T... if any of that crap were true, it would be plastered all over the FSM's. i'm not saying that there hasn't been a failure after a flush, but i'd bet those transmissions had issues before the flush, and in desperation the owner (or shop) tried a full service as a last resort. shortly after, the transmission fails - blame the flush. ...and the legend begins.
Old Mar 18, 2013 | 07:58 AM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
Not really.
Then explain why my leaks stooped when I changed back to recommended weight dino after 24 years of synthetic
Old Mar 18, 2013 | 08:06 AM
Polo Vert's Avatar
Polo Vert
All BS aside, to answer the simple question..YES, it is ok to run Royal Purple brand but stick to the correct viscosity for the car. Is it necessary or will it help performance? Not so you would actually notice it.
Old Mar 18, 2013 | 09:22 AM
aklim's Avatar
aklim
I'll bet I can't either. What it probably came from is someone who flushed his trans as it was on it's last legs in the hopes that it will miracle itself into healing and it didn't.
Old Mar 18, 2013 | 09:24 AM
aklim's Avatar
aklim
Originally Posted by Cruisinfanatic
Not really.
I have done it with high and low mileage cars and so far, we have not found a single leak that could be attributed to the oil. Just because it is unexplained doesn't mean the first answer that comes to mind is the right one.
Old Mar 18, 2013 | 10:10 AM
Cruisinfanatic
Pretty obvious to me.
Use Mobil 1 since new, develop leaks over the next 20 + years. Leaks stop after switching to regular 5-30 oil. Was suggested to try it from the local vette shop. Nothing else was done.
It worked
Old Mar 18, 2013 | 10:45 AM
Tom400CFI's Avatar
Tom400CFI
Pro Mechanic
^There it is then^ Scientific PROOF!
There are many reasons why it MAY have stopped leaking, if in fact it stopped leaking, slowed or whatever. I have more than your one anecdotal example, but going the other way, that "proves" that synthetic oil doesn't cause leaks -as I have swapped every car I've owned TO, synthetic after buying it. These would all (but two of them) be considered "high mile". I would guess that the additive package in your conventional oil had something to help older seals...but don't know.
It's cool for you however, that you fixed you oil leaks w/an oil change.
To oil
Old Mar 18, 2013 | 11:15 AM
skyhawk50's Avatar
skyhawk50
I had an MGB, that when it stopped leaking oil, it meant it was out of oil.
Old Mar 18, 2013 | 01:24 PM
Aaron Keating's Avatar
Aaron Keating
Not really.
Crap in the dino oil.
Crudded up your seals.
And crudded up your engine too.
Old Mar 18, 2013 | 01:38 PM
ckwhite's Avatar
ckwhite
Besides synthetics, which I don't think you want to switch to at this stage of the game, UNOCAL's Royal Triton Purple is probably the finest motor oil you can buy. Problem: It's not being made anymore, so buy it up whenever you can find it!
[IMG][/IMG]
