84 Cooling issue
Old Mar 25, 2013 | 01:11 PM
Aardvarkus's Avatar
Aardvarkus
4th Gear
Default 84 Cooling issue
Just installed a newly rebuilt engine, all cooling sensors are new but when I start the engine and run it for about 10-15 minutes the temp reading on the LCD starts at LO then goes to about 160 F and then drops to LO in about 2 minutes after the thermostat opens up and stays there. Therefore the cooling fan does does not come on and the car starts to overheat. I've checked all of the block grounds, checked the coolant sensor resistance at ambient which reads about 3200 ohms (didn't check when it was hot). What am I missing?
