Grease Gun Question
Old Apr 2, 2013 | 01:55 PM
aklim's Avatar
aklim
Default Grease Gun Question
Is a grease gun a good investment? From years of personal experience, I'd have to say "NO". Every gun works the day you install the cartridge. After that, if you are not using it daily, all it does is leave a mess and when the time comes, it doesn't have any charge and you have to get a new cartridge.
All in all, I am not sure what to do except to get a Lube Oil Filter every so often and get them to grease it as the most economical option. I am sick and tired of oil drips all over and not being able to use it when it counts.
Any ideas? I have seen a catcher for the oil drips but all that does is catch the oil. Meanwhile, the gun is worthless except for 1 use then buy another cartridge.
Old Apr 2, 2013 | 02:13 PM
92ragtop's Avatar
92ragtop
2019 C4 of Year Finalist (appearance mods)
2015 C4 of Year Finalist
Not sure why yours is only good for 1 use. Get a small manual grease gun that uses a pump handle to force the grease out.
Old Apr 2, 2013 | 02:26 PM
aklim's Avatar
aklim
That is how mine are. Manual pump. Small or regular size both leak after a while
Old Apr 2, 2013 | 02:49 PM
Silver96ce's Avatar
Silver96ce
I have two old manual grease guns and an air operated one - none of them have ever leaked the grease out. I have one of the old ones with a cartridge I put in a few years ago -used it last year with no problems. The air one has had the same cartridge since 2011 when I used it to pump grease into a wheel bearing greaser. It has not leaked since then.
Quick question - do you have the spring loaded plunger at the back (usually has a T handle)? If so, try pulling it back (and leaving it in the notch for when you reload) after each use to relieve pressure.
Old Apr 2, 2013 | 03:17 PM
TommyFox's Avatar
TommyFox
Did you buy a cheap one?
I store mine in the basement so the summer heat doesn't cause it to drip.
Old Apr 2, 2013 | 03:41 PM
aklim's Avatar
aklim
I have gotten them from Wal*Mart or parts stores. It isn't the grease that drips it is some sort of lighter liquid that seems to be squeezed out of the oil. Not sure what it is.
Old Apr 2, 2013 | 03:45 PM
Analog Kid's Avatar
Analog Kid
I thought it was just me. My grease gun constantly dripped oil on the floor making a mess. But....... if you want something done right you have to do it yourself and wiping up some oil drops once in a while is a small price to pay for knowing that I actually lubed those ball joints.
Old Apr 2, 2013 | 03:48 PM
aklim's Avatar
aklim
Not only the oil on the floor, it loses it's prime. Seems like the best thing is to buy it, use it and toss the tube of grease and when you need it again, buy another tube.
I have used cheap stuff and the best the auto parts stores have to offer and still I lose the prime and lose the oily stuff on the floor. I was so pissed I threw the gun in the garbage and went down and got GM to grease my 6 zerks in front of me.
What does the future hold? Do I have to constantly get new tubes or what?
Old Apr 2, 2013 | 04:10 PM
TommyFox's Avatar
TommyFox
Get one from Snap On or ask the GM dealer what brand they buy.
Old Apr 2, 2013 | 04:18 PM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Good idea about relieving the pressure when storing. I buy the same kind of grease guns and have a special spot on my shelf where I store it. It is lined with a towel and I have a shop towel wrapped around the tip. It does leak some goop but not too bad.
In one of the C4 maintenance classes I attended the instructor said to beware of taking your Corvette to an oil change joint. The instructor said that they use so much pressure when they lube your ball joints that it blows them out. Sounds like it is best to do it yourself even if it is messy and inconvenient.
Old Apr 2, 2013 | 04:32 PM
aklim's Avatar
aklim
They have one that is air pressured. I am looking for the pistol style.
Old Apr 2, 2013 | 04:34 PM
FASTAZU's Avatar
FASTAZU
2018 C4 of Year Finalist
2015 C4 of the Year Finalist
St. Jude Donor '16
I always store mine after use with the pump handle open and hung on a peg never had any issue with it leaking or dripping.
Old Apr 2, 2013 | 05:12 PM
Red Dwarf's Avatar
Red Dwarf
I found that if not used on a somewhat regualr basis the grease tends to separate
I only use mine twice a year & have the same problems as you.
Old Apr 2, 2013 | 05:26 PM
aklim's Avatar
aklim
Meaning what? You remove the tube from the pump top?
Old Apr 2, 2013 | 06:13 PM
383vett's Avatar
383vett
Unless you use it often, forget the pressurized unit and get a simple pump grease gun with a handle. They last forever. I've had mine for decades with no problem. Cartridges are only a couple bucks.
Old Apr 2, 2013 | 07:45 PM
jmgtp's Avatar
jmgtp
Mine gets a coating of grease all over it that makes it a disgusting mess that I keep in a plastic bag. It's my own faut though, get my greasy fingers all over it. I use it once a year to grease all the cars. No idea what brand it is, I've had it a while. I haven't noticed any leaking just the greasy coating. Reminds me to get a new cartridge
Old Apr 2, 2013 | 07:51 PM
aklim's Avatar
aklim
Got a brand and model in mind?
To Grease Gun Question
Old Apr 2, 2013 | 07:57 PM
aklim's Avatar
aklim
383Vette, Did you mean this?
http://www.acehardware.com/family/in...goryId=1258977
I have THIS:
http://www.legacymfg.com/products/dy...umberID=L1185L
Old Apr 2, 2013 | 09:57 PM
TommyFox's Avatar
TommyFox
That's what I got but he has his heart set on a pistol grip.
Old Apr 2, 2013 | 10:17 PM
aklim's Avatar
aklim
Is there any difference between the pistol and the lever? They both seem to have the pull spring at the bottom which pressurizes the grease.
That said, if the lever one doesn't pressurize the grease, I might just switch.
Does it pressurize the grease then? It looks like it since it has the "T" shaped thing below.
