uh oh....blinker not blinking
Old Jun 19, 2002 | 01:13 PM
slvrsrpnt's Avatar
slvrsrpnt
Default uh oh....blinker not blinking
When putting on the left directional, the light stays solid, but when doing the right directional it flashes correctly. Is this normally a fuse or flasher problem? And, where is the flasher thingie located if that's what the problem most likely is ? Don't mind my ramblings...woot, hit 100 posts!
Old Jun 19, 2002 | 01:14 PM
96LT4's Avatar
96LT4
Former Moderator
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
CI3 Car Show Winner
Default Re: uh oh....blinker not blinking (slvrsrpnt)
You probably have a bulb that is burnt out. :cheers:
Old Jun 19, 2002 | 01:37 PM
slvrsrpnt's Avatar
slvrsrpnt
The bulbs themselves light up, but do not flash
Old Jun 19, 2002 | 01:38 PM
scorp508's Avatar
scorp508
You probably burned out only one of the fillaments in the bulb. There are 2 in there. Check every bulb on whatever side of the car isn't flashing.
Both taillights on that side, front turn signal, and side.
Old Jun 19, 2002 | 01:51 PM
slvrsrpnt's Avatar
slvrsrpnt
ok, one more silly question, will this make the diplay in the dash also stay as a solid non blinking light? (as you can tell, I am mechanically ignorant)
Old Jun 19, 2002 | 01:55 PM
GS 163's Avatar
GS 163
Default Re: (scorp508)
and yes, it will cause the flaher on the dash to stay solid. I had one go out last weekend.
Old Jun 19, 2002 | 02:22 PM
Vmc's Avatar
Vmc
Default Re: (JPLT1)
....You need to check the reservoir, you probably ran out of Blinker Fluid on that side, just fill it up and you'll be ok..............Discount Auto has it, my wife got some after the mechanic told her she needed some!!........ :lol: :lol: J/K
Old Jun 19, 2002 | 02:41 PM
ChrstphrM's Avatar
ChrstphrM
Default Re: (DCTC)
That was just plain nasty. Everyone knows that the blinkers have run on a gas cartridge since 89. :reddevil
Old Jun 19, 2002 | 02:45 PM
ChrstphrM's Avatar
ChrstphrM
Default Re: (ChrstphrM)
But seriously folks. The Vette is designed so that when a bulb goes out, the blinker stays solid. Bulbs are cheap. So, when you replace one, just replace them all. That way you don't have to keep doing it every month or so. Its cheap easy and lets you drive for years between bulb changing episodes.
Old Jun 19, 2002 | 03:01 PM
96LT4's Avatar
96LT4
Former Moderator
Cruise-In V Veteran
CI3 Car Show Winner
Default Re: (DCTC)
Blinker fluid? LOL!! Make sure you use the synthetic kind too.
As I and others have said, you have a burnt bulb. And, I would suggest relacing them all so you don't have to do it again any time soon. :cheers:
Old Jun 19, 2002 | 07:09 PM
GDP's Avatar
GDP
100 posts! I just hit 100 not to long ago. :cheers:
Old Jun 19, 2002 | 07:11 PM
LT5's Avatar
LT5
Default Re: uh oh....blinker not blinking (96LT4)
:yesnod:
Old Jun 20, 2002 | 12:37 AM
Lord_Auric's Avatar
Lord_Auric
Had the same problem in my old firebird. It wasn't the bulb it was actually the little bulb holder itself, just got a new on from the junk yard and installed it myself. It's fairly easy. So if it isn't the bulb try the bulb holder. Mine got really hot that is how I knew it was bad BTW.
Old Jun 20, 2002 | 01:11 AM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
It's like that on most cars, not just vettes.
Old Jun 20, 2002 | 09:01 AM
slvrsrpnt's Avatar
slvrsrpnt
All better, replaced a few bulbs and topped off headlight fluid to play things safe.
To uh oh....blinker not blinking
