86 corvette
Old Apr 7, 2013 | 10:32 PM
jdavis62024's Avatar
jdavis62024
Default 86 corvette
I have a problem and I need help. I went into a store and came out and the car would not turn over or do anything. so I pushed it home.I went to work and when I got off I tried to start it and it started right up. it has a new battery and started. what is my problem. please help
Old Apr 7, 2013 | 10:44 PM
True Mountaneer's Avatar
True Mountaneer
You really need to give more info,Were your dash lites coming on with the key,or was every thing dead,could be a bad or loose cable going to your starteror solinoid.Is your starter shielded from heat,and oil leaks?.If it's a standard it could even be the clutch pedal switch .I'm sure sombody here can figure it out.
Old Apr 7, 2013 | 11:02 PM
jdavis62024
I have power to everything. its a auto. there is no heat shield on the starter. it started right up in the morning and drove it maybe 3 blocks from the house.so I don't think it could be cause the heat. when I turn the key its like dead. let off key I have power.
Old Apr 7, 2013 | 11:47 PM
84VetteMan205hp's Avatar
84VetteMan205hp
check your battery cables and clean them dip them in pepsi.
Old Apr 7, 2013 | 11:56 PM
jdavis62024
They are brand new battery cables new battery and starter .
Old Apr 7, 2013 | 11:58 PM
Cygnus's Avatar
Cygnus
Sounds like a dead starter or a wire short in between
Old Apr 7, 2013 | 11:59 PM
jdavis62024
Its brand new 2 days old
Old Apr 8, 2013 | 12:03 AM
jdavis62024
Could it be a neutral safety sensor
Cygnus's Avatar
Cygnus
I would begin with checking all the wires/cables to make sure they are in good condition and tight. If they are, I would pull the starter and have it tested. Sometimes new parts have an issue.
If you have power, the battery isn't the issue, but the starter or cap/rotor could be.
Old Apr 8, 2013 | 12:05 AM
jdavis62024
It aint had a tune up since 09 the guy said when I bought the car
Old Apr 8, 2013 | 12:09 AM
vetteoz's Avatar
vetteoz
Sounds like VATS,
http://www.thirdgen.org/vats_passkey_system
With the common pellet in the key not being read correctly problem seeing it started up fine later on
(which takes out a battery / cable / NS switch /starter problems)
Old Apr 8, 2013 | 12:12 AM
jdavis62024
It has a chip in the key how would I fix that then
Old Apr 8, 2013 | 12:18 AM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Clean key with alcohol. Leave it wet and insert/remove from the ignition lock several times rapidly. Sometimes this removes the crud and allows everything to work fine. The VATS system also has a timer on it which will not allow the car to start for a period of time (15 min - can't remember). This kicks in if the system senses it has been tampered with.
If this continues then you might need a new lock cylinder and key. If you go that route you must have your key's chip read first so you can get a replacement set that matches your current key's code.
If that does not help then post up again as there are other ways around it.
Old Apr 8, 2013 | 12:22 AM
jdavis62024
Ok will try that thanks for all the help
Old Apr 8, 2013 | 12:26 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
That's not the problem.
This is a power/switch issue.
Old Apr 8, 2013 | 03:14 AM
Cliff Harris's Avatar
Cliff Harris
Check out this web site for a lot of info on VATS:
http://www.joestradingpost.com/vats/
There was a recall on the ignition switches for '86. The contacts were changed. I did the upgrade and the new switch came with new keys (longer than the old ones). This was a LONG time ago, so good luck with that.
Old Apr 8, 2013 | 04:35 AM
vetteoz's Avatar
vetteoz
Originally Posted by Cliff Harris
There was a recall on the ignition switches This was a LONG time ago.
1988
Even if the replacement was done as part of the TSB #88-292-8A
http://www.corvetteactioncenter.com/...i-Theft+System
this far down the track either the key or contacts could be due for replacement again
To 86 corvette
Old Apr 8, 2013 | 08:29 AM
True Mountaneer
This is just grabbing at straws,but it could possibly be your shifter position,Don't put much pressure on it but shove up a little bit on it and try it ,or try starting it in neutral....Have you tried turning the key on,opening the hood,and sparking the solinoid?
Old Apr 8, 2013 | 02:20 PM
jdavis62024
Did that and turns over
Old Apr 8, 2013 | 03:09 PM
DinoBob's Avatar
DinoBob
Your other post says it does while running so I doubt the neutral switch is the cause. I'd more suspect the VATS. Thank God my PO bypassed mine.
