86 corvette
Old Apr 8, 2013 | 02:17 PM
jdavis62024's Avatar
jdavis62024
Default 86 corvette
I was driving down the road and it started to cut out and then it just died. pulled over and It started back up. it did this a few times. then I get home shut it off and tried to start it and would not turn over or do anything. when I turn the key I have power to everything. waited 2 hrs and it started right up
Old Apr 8, 2013 | 03:05 PM
DinoBob's Avatar
DinoBob
Perhaps there is some relevance found in the 17 replies to your other post.
Old Apr 8, 2013 | 05:21 PM
pmihaltian's Avatar
pmihaltian
Slingshot
Sounds like a possible failing fuel pump. These in-tank pumps have a life span of approximately 75000 - 85000 miles. Check the fuel pressure at the fuel rail on the passenger side of the engine. If it is weak or fluctuates - consider installing a new fuel pump.
To 86 corvette
