Shift to four light problem!! Auto Trans??
Old Apr 10, 2013 | 01:17 PM
scottvettec4's Avatar
scottvettec4
Default Shift to four light problem!! Auto Trans??
I have a 1990 Automatic but when I take off a light comes on that says shift to four. I thought this was only on Manual transmissions? Please help. Thanks in advance.
Old Apr 10, 2013 | 01:25 PM
AirForceOne!'s Avatar
AirForceOne!
Hmmm, mine's never done this? I always drive in 4th gear, maybe that's why? What gear do you start out in?
Old Apr 10, 2013 | 01:26 PM
TorchTarga94's Avatar
TorchTarga94
Sounds like someone may have swapped in an auto at some point?
Old Apr 10, 2013 | 01:36 PM
scottvettec4
Thanks so far. Can anyone tell me what controls this. Is it the ecm or the prom chip. maybe someone swapped out the computer at some point. An automatic should not be doing this.
Old Apr 10, 2013 | 01:45 PM
tbirdsps's Avatar
tbirdsps
My 90 has the 700R4 from the factory and I have a "shift up" light. I noticed it when I was on the highway in D3 vs D4.
Old Apr 10, 2013 | 02:16 PM
scottvettec4
So I guess its ok then. Can we disable this by any chance?
Old Apr 10, 2013 | 04:54 PM
AirForceOne!
I've never drove in D3, always in D4 and my 90 never lights up!
Old Apr 10, 2013 | 05:33 PM
tbirdsps's Avatar
tbirdsps
I pretty much always use D3 around town. Above 40mph I go to D4.
Old Apr 10, 2013 | 10:22 PM
Corvette40's Avatar
Corvette40
My shift light illuminates when I forget to shift to overdrive when getting on the freeway.
Old Apr 10, 2013 | 10:54 PM
eutu1984's Avatar
eutu1984
2021 C4 of the Year - Modified Finalist
Same for mine. If I am in 3rd it will give the shift light once your up to speed.
Old Apr 10, 2013 | 11:10 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Narrow or wide brake pedal?
Of course a clutch pedal and an automatic would be a dead give away
Old Apr 11, 2013 | 02:46 AM
Cliff Harris's Avatar
Cliff Harris
The shift light is controlled by the ECM. It turns it on at about 40 MPH. It will turn the shift light on if you're not in OD (4th gear). That applies to 1st, 2nd and 3rd.
Old Apr 11, 2013 | 12:46 PM
scottvettec4
But it is a automatic transmission and the shift to four light is coming on.
Old Apr 11, 2013 | 12:47 PM
scottvettec4
Is yours an auto or manual?
Old Apr 11, 2013 | 01:45 PM
AirForceOne!
Cliff Harris is talking about an automatic.
Old Apr 11, 2013 | 07:41 PM
mazdaverx7's Avatar
mazdaverx7
does it say "shift to four" or "one to four"?
Old Apr 12, 2013 | 02:31 AM
Cliff Harris
The original poster said he has an automatic. That's what I based my reply on.
It appears that someone has replaced his cluster with one from a manual trans car.
Old Apr 12, 2013 | 01:38 PM
SunCr's Avatar
SunCr
Auto was disabled in '89. Someone put something else in yours if it's an Auto and lights up.
To Shift to four light problem!! Auto Trans??
