What is NORMAL operating temp?
Old Apr 15, 2013 | 09:03 PM
PHILLIE PHANATIC's Avatar
PHILLIE PHANATIC
Default What is NORMAL operating temp?
I have a stock 1990 L98 convertible, my wife and I went out for a drive yesterday, it was 55 degrees. We drove 45 min, stopped for about 1 hour and 45 min home. The temp gauge never went above 150, is this normal? I thought that they normally average around 200. Thanks in advance for any replies.
Old Apr 15, 2013 | 09:08 PM
True Mountaneer's Avatar
True Mountaneer
I don't know how long you've had the car,but I'd say somebody took th e thermostat out.
Old Apr 15, 2013 | 09:13 PM
PHILLIE PHANATIC
That's what someone at work said. Is that OK? I don't want to do any damage.
Old Apr 15, 2013 | 09:30 PM
True Mountaneer
I would put a 190 in it just to keep your oil dry(free of moisture)....Living in New England you will need heat and defrost at times too.
Old Apr 15, 2013 | 09:55 PM
65GGvert's Avatar
65GGvert
Does the heat work? You might shoot the thermo housing with an infrared temp gun to verify the sensor. The thermostat may be in there, but stuck open. If it's truly at 150, I wouldn't think the heater would get very hot.
Old Apr 16, 2013 | 02:28 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
I run a 160deg T-stat in my '88 (did it in prior '88 for >12yrs with no ill effects) and the gauge runs around 155deg on highway. I just do not like the engine running in the 210-215deg range; it still provided good heat on cold winter days.
I also run full synthetic motor oil changed at regular intervals so have no worries about engine damage.
Old Apr 16, 2013 | 06:47 AM
PHILLIE PHANATIC
Thanks guys, I've had the car 2 yrs and I always am looking at my gauges, but for some reason until the other day it never crossed my mind that it was running low temp. I have had the heat on, and I do get heat out of it, but I don't take it out in the winter. To change the subject my thoughts & prayers go out to everyone that was injured at the Boston Marathon yesterday.
To What is NORMAL operating temp?
