Need Info
Old Jun 21, 2002 | 11:39 AM
champs_97's Avatar
champs_97
Default Need Info
Paperclip trick instructions for a newby owner?????
Old Jun 21, 2002 | 11:43 AM
War Machine's Avatar
War Machine
From: Airport Cruise-in 1 Veteran Airport Cruise-in 2 Veteran
Cruise-In II Veteran
Default Re: Need Info (champs_97)
The two top right hand terminals (“A” and “B”) in the connector.
Old Jun 21, 2002 | 11:47 AM
vader86's Avatar
vader86
Just above your right knee, where the carpeting from the dash and instrument area meet there is an ALDL connector. Yours may still have the covering piece on it.
Anyway, youll want to bend a paper clip open and stick the ends of it into the two farthest holes on the right. One on top of the other
like this:
with your ignition key turned, but not started up
Old Jun 21, 2002 | 12:00 PM
champs_97's Avatar
champs_97
Default Re: Need Info (vader86)
Thanks. What do you use for the indicator of the codes?
Old Jun 21, 2002 | 01:30 PM
War Machine
The Service engine soon light. It will blink once and then twice (code 12) for 3 times to start. Then the codes, if any, will flash. For example 3 flashes, pause, 2 flashes is code 32.
Old Jun 22, 2002 | 10:17 PM
thrills's Avatar
thrills
Moderatrix
Cruise-In IV Veteran
like this:
:confused: Mine are like this:
The bottom one is empty, a dummie slot. I just pulled codes today with my trusty clip, if you're doing it right the fans will come on and it will take a few seconds before the first code flashes, BLINK (pause) BLINK BLINK "12" is always going to blink at the beginning AND end, it's your baseline code. All errors fall in between in numeric order.
[Modified by thrills, 8:18 PM 6/22/2002]
To Need Info
