unknown part on 94 vette
Old May 3, 2013 | 09:17 PM
Erniep's Avatar
Erniep
Default unknown part on 94 vette
Can someone tell me what this is ? I need the elbow vacuum hose on it..
Old May 3, 2013 | 09:43 PM
WVZR-1's Avatar
WVZR-1
I believe likely the cannister purge solenoid. There should be a number on it like maybe a three digit number preceded by a DR
Old May 3, 2013 | 09:47 PM
Erniep's Avatar
Erniep
ok, thanks
Old May 3, 2013 | 10:05 PM
WVZR-1's Avatar
WVZR-1
Originally Posted by Erniep
ok, thanks
I believe you want a GM# 10105299 but I believe it's likely NLA.
#538 in this image
Old May 3, 2013 | 10:12 PM
Erniep's Avatar
Erniep
#538 in this image
Thanks, I thought that would be a hard part to get. I taped the hose up for now. Nice diagram.
Old May 6, 2013 | 12:05 AM
Phat98's Avatar
Phat98
That hose on my '94 was in worse shape than that. I found a piece in the Dorman section (HELP) of the local Autozone that fit and fixed it right up, seems I may have trimmed a little off. Sorry, it's been a few years back and I don't have the numbers for you.
Old May 6, 2013 | 07:28 AM
Erniep's Avatar
Erniep
Thanks for the info. Hopefully AutoZone still has that hose.
Old May 6, 2013 | 08:32 AM
WVZR-1's Avatar
WVZR-1
Not ever attempting to use the "HELP" branded part and I would have guessed that maybe this elbow actually might have had a different ID on either end BUT the 47029 which is a MOPAR PCV elbow replacement might be the referenced part.
It was early 90's and the OE was 4536156 and might be less expensive if it's a fit from the dealer. Maybe?
Old May 6, 2013 | 12:33 PM
Erniep's Avatar
Erniep
I Appreciate the replies. Thanks again
Old May 6, 2013 | 01:26 PM
mxw128's Avatar
mxw128
I couldn't find a molded part so I just used some vacuum hose that fit the solenoid side and crammed it onto the TB nipple.
To unknown part on 94 vette
