Oops "Senior Moment"
Old May 17, 2013 | 05:42 PM
93 ragtop's Avatar
93 ragtop
Originally Posted by Cruisinfanatic
I think E85 in a C4 is a BIG no no
Why do you say that? Its tuned for it.
http://forums.corvetteforum.com/c4-t...ts-are-in.html
Old May 17, 2013 | 06:17 PM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
Mines not
The OP's is likely not
Old May 17, 2013 | 06:57 PM
DinoBob's Avatar
DinoBob
Originally Posted by Firewalker11
Keep in mind, there are not different gas tankers that show up to fill each respective tank. The gas stations have one large tank and add the octane to it to achieve regular and premium grades. Your car will be fine and probably will not hiccup at all.
Ha ha ha ha.
Old May 17, 2013 | 08:21 PM
93 ragtop's Avatar
93 ragtop
Mines not
Not sure where you are going with this. I never said that the OP or you should try it. I only made the comment due to a previous post by Greggpenn stating that the ethanol raises octane. As a matter of fact go back a little further and I said that the octane of 87 would be fine in a 85 car.
Old May 17, 2013 | 09:11 PM
84VetteMan205hp's Avatar
84VetteMan205hp
E85 in any car is a big no no unless its tuned for it.
Old May 17, 2013 | 09:32 PM
93 ragtop's Avatar
93 ragtop
Originally Posted by 84VetteMan205hp
E85 or E-anything will eat away the hoses, rust out the tank, gas lines ect... and it makes your motor hotter.
You really need to check your facts. 1. most all gas is now 10 percent "E" 2. the tank in a c4 is lined. 3. Go down to your local drag strip and tell the guys how alchol makes a motor run hot!!
Old May 17, 2013 | 09:33 PM
93 ragtop's Avatar
93 ragtop
[QUOTE=84VetteMan205hp;1583927827] E85 in any car is a big no no unless its tuned for it.[/QUOTE]
Hello, go back and read post 21
Old May 17, 2013 | 10:29 PM
Cruisinfanatic
Hello, go back and read post 21[/QUOTE]
How do we know you have a specially tuned car unless we read all of your posts?
Old May 17, 2013 | 11:34 PM
H P Bushrod's Avatar
H P Bushrod
Moderator Emeritus
St. Jude 15 Year Donor
CI 5 thru 12 Veteran
St. Jude Donor '09 thru '23
Old May 18, 2013 | 01:33 AM
Cliff Harris's Avatar
Cliff Harris
Originally Posted by GREGGPENN
Because of ethanol, some 87 is 89 too. Someone posted a chart (last year?) that showed measured ratings for many brands. The results were interesting. IIRC, most levels were at or above minimums. Not lower, as suggested above.
Again, a by-product (advantage) of ethanol.
I think it's the other way around. In California the highest grade we can get is 91 octane because of the ethanol.
Old May 18, 2013 | 01:42 AM
Cliff Harris
This is totally wrong. I have been in the control room at the Chevron refinery in Torrance, California when they were blending gasoline. The senior guy is the only one who does it. They have guys out in the tank farm with radios at the manual valves in case anything goes wrong with the computer-controlled valves. The guy on the computer is in constant radio contact with the guys in the tank farm so they know exactly what is happening. It's a VERY intense process and NOBODY talks while they are blending.
Old May 18, 2013 | 05:39 AM
93 ragtop's Avatar
93 ragtop
[QUOTE=Cruisinfanatic;1583928405]Hello, go back and read post 21[/QUOTE]
How do we know you have a specially tuned car unless we read all of your posts?[/QUOTE]
No need to go back and read my post. Just read the comments in the post you are adding to. Again number 21
Old May 18, 2013 | 05:44 AM
  #33
93 ragtop's Avatar
93 ragtop
Cliff, I have no idea why you can only get 91 octane in Cal. But its true the ethanol raises the octane. That is why E85 in my area is 104. Premium gas is 92-93
I was told that E98 is actually 110 octane.
Old May 18, 2013 | 07:52 AM
  #34
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
It's not going to hurt, read your manual, you might be surprised.
Old May 18, 2013 | 12:42 PM
  #35
abdo's Avatar
abdo
2016 C1 of Year Finalist
Where I live I can get 89 octane with no ethanol. I tried some 87 octane with 10% ethanol in my '86 Coupe and I could notice a slight difference. No knocks, but slightly less performance and slightly lower MPG. I'll stay with the premium.
Old May 18, 2013 | 01:14 PM
  #36
93 ragtop's Avatar
93 ragtop
Absolutely stay away if you are not tuned for it and or pure gas is available. You need approximately 30 percent more e85 then pure gas, so at best mileage will decrease 30 or so percent.
The problem with going pure gas is, in many areas its just not available.
The advantage to E85 is less pollution and its made from corn., that's why its out there. But for me and a lot of others, due to it being 104 octane, and it runs cooler, you can take advantage of this with additional timing in a high compression motor, or additional boost on a blower motor, and again running cooler.
Old May 19, 2013 | 04:44 PM
  #37
WGlen C4's Avatar
WGlen C4
Kidding right?
I used to deliver fuel. Yes one tanker, five sections to hold fuels. Next time you go to the gas station look at the different color covers on the tank heads. Must be kidding...
To Oops "Senior Moment"
Old May 19, 2013 | 05:42 PM
  #38
ch@0s's Avatar
ch@0s
Originally Posted by WGlen C4
Kidding right?
I don't think he was kidding.
Old May 20, 2013 | 12:40 PM
  #39
J W Drew's Avatar
J W Drew
Default Question?
Originally Posted by J W Drew
Went to gas up my 85 yesterday. Now, my daily driver uses 87 octane so without thinking, I filled the Vette up with 87 octane (usally use 89). Since I don't drive the Vette that much this will take about 3 months to use up. Guess I will just nurse it untill the next fill up.
JW
Thanks for all your responses. Question, I'm schedued to take the 85 to the shop for a tuneup on 6/2. Was wondering how the effect of the 87 octane in the tank would effect the the process?
JW
Old May 20, 2013 | 01:49 PM
  #40
Cruisinfanatic
JW
it won't.
It was recommended for an 85
