I have a 1991 coupé. Now I'm finally replacing my partially broken Bose system.
What I would like to find out is the volume of the rear speaker boxes/cabinets/compartments.
If these compartments proves to be of any use, I plan to set up a system with bass speakers in these boxes, mids in the front and tweeters on the dash. I would like to avoid anything visible but I can accept small tweeters on the dash.
If nobody can tell me the volume, I will eventually fill them with water to find out but I was hoping not to have to.
Head unit will be a Pioneer P88RS-II wich opens up allmost any possibility.
Reason: Clearyfying
C4 of Year Winner (appearance mods) 2019
If you are talking about the factory rear speaker compartments (versus the storage bins), they are quite small. I am certain they are smaller than one cubic foot and really think they're in the 1/2 cf range. (I measured almost 10 yrs ago! LOL) The factory did place a piece of foam in the enclosure to help it ACT larger than 1/2 cf. (This is common practice for sealed/ported enclosures...as it slows wall-to-wall reflections -- as if it were a bigger box.)
People convert to 6x9 or 8" woofers back there. I did the later....looking for the drivers with the smallest enclosure requirement. Keep in mind that you can use speakers designed for larger enclosures (like 1 cf) but you lose low-end response. In the small confines of a car, you lose it anyway. Kinda means it's nothing to get bent-out-of-shape over.
You should be able to find 8" subs good for a 1/2' - 1' enclosure. Of course, any good [high power] 6x9" would work too.
GREGGPEN,
Thank you for your reply! Exactly what was looking for.
Yes, it's the speaker compartments I'm talking about.
My guess would have been less than 1/2 a cf more likely a third. I found no foam in my enclosures but I know what you are talking about.
Today's speakers are so much improved over older ones (Q values) so you don't necessarily need to have large open enclosures to obtain a good sound. In my Audi A3 I had a single JBL GTO804 in 0.3 cf sealed enclosure (factory recommendation). Incredable sound! Actually, the shop rated my installation as competition class while listening to the result. If you don't install properly, it doesn't matter how exclusive stuff you buy. Using that woofer I need to worrie about all other walls than the baffle instead ;-)
If your'e not familiar with the GTO804 already, I can highly recommend it.
My experiences regarding low end response are not the same as yours. I'd rather like to create a hole in the frequency range between app 80 to 200 Hz since that range comes by itself.
I filled my spaces up with some foam peanuts as a test and estimated it to be just a little under 1cf of air space after measuring the amount of peanuts I was able to put in there. I didn't leave the peanuts in there. I put some 8" woofers in mine and they sound great as a sealed enclosure.
Originally Posted by GKK
Remember to include your Sub after adding the packing peanuts too, get an accurate volume measurement.
I can't remember if that's necessary. I used to think this...but thought I read where the [protruding] cone doesn't hamper creation of sound waves inside the box. So, you might be able to take only box-size into consideration.
A couple of days ago I recieved the Metra kit which allows me to install a single din CD player in the gigantic hole after the Delco/Bose thing was removed. Kind of cheap looking but it will hopefully do its job. Another surprise was the "nuts" in the CD player. A player that in those days was considered to be high end should have better holes than this.
Reason: Picture didnt upload correctly
