High idle problem solved...
Old May 19, 2013 | 07:58 PM
WGlen C4's Avatar
WGlen C4
Default High idle problem solved...
Since buying my 1991 in September it has idled high. It was high enough that the tranny was trying to go and I was holding the car back at traffic lights. I would just shift into Neutral. Also when I would hit the cruise button to drop a MPH, the car would slow and then speed up even faster. If I tried to set the cruise @ 30 mph it would go right to 36.
I understood that I couldn't adjust the idle because it was in the ECM. I read that there is an idle screw, but it was blocked off @ the factory. I had access to a ODP scanner at work but I really don't know much about it. I have a former background in ladder logic and CNC programming so I thought I could figure it out.
Anyway I had a chance to look at it today. Someone had popped out the plug for the idle screw hole, so I'm guessing this was an issue for the last owner.
When I backed the screw off the throttle plate didn't move with it. This made me think that the return spring was loose/broken or needed adjustment. I grabbed the tools to take all the cables off the plate so I could see how to adjust the spring. When I took off the cruise control linkage I noticed that the plate was up against the idle screw. I backed the screw off more and the plate moved more.
I started the car and it idled right down to 850 or 900 rpm's
I looked at the other end to see if there was adjustment to the cruise cable. There was 6 or 8 different holes for the cable to clip into, so I tried the next hole that would loosen it up.
Took it for a test run and it works perfectly. It idles great at lights and the cruise works like the one in my pickup (same lever).
Old May 19, 2013 | 10:44 PM
daddysvet92's Avatar
daddysvet92
Awe that feeling when you fix it and it runs good after that!!!
Now drive it and enjoy the beautiful days to come!!
Great job...
Old May 19, 2013 | 11:17 PM
Frizlefrak's Avatar
Frizlefrak
Yep...the minimum air screw is sealed at the factory....for a reason. It shouldn't be messed with.
The previous owner on your car had an idle issue....and messed with the screw instead of fixing the real cause of the idle problem correctly. I had the same thing on my Fiero....chased an idle problem forever. Never thought to look at the minimum air screw because....drum roll please....it should be sealed. It wasn't. I reset minimum air per the FSM, and it now idles perfectly.
Old May 22, 2013 | 04:31 PM
WGlen C4's Avatar
WGlen C4
Another nice thing...My average MPG on my daily commute went from 20.5 avg to 24.9 avg.
To High idle problem solved...
