C4 Power Windows - HELP - 1985 - HELP
Old May 20, 2013 | 08:29 AM
OchoCincoC4's Avatar
OchoCincoC4
4th Gear
Default C4 Power Windows - HELP - 1985 - HELP
Welp i think this is a self induced wound - but here it goes, I installed a nice JVC audio indash unit and everything was fine worked great and sounds awesome. Shortly after install, I decided to rolldown my windows, welp no luck...which is why i'm here now. So the issue is both windows will not go down or up - they dont event make a noise or attempt to move. I've check the fuse and its fine. I checked power to both driver/passenger side toggles and they have power flowing in up/down position. I pulled the door panel off and tested prior and post the connection block and have verified power to the motor. I'm stuck and dont really want to take it to a shop. Not sure what else to try or check - any help greatly appreciated - Thanks Kevin
Old May 20, 2013 | 10:02 AM
ejscarfo's Avatar
ejscarfo
Did you remove the center console trim piece that holds the window switches when you did the radio install?
Old May 20, 2013 | 10:16 AM
OchoCincoC4
4th Gear
yes ejscarfo - I removed the center piece along with the center dash.
Old May 20, 2013 | 10:41 AM
ejscarfo's Avatar
ejscarfo
Perhaps one of the wires coming from the switches in the console was disturbed during your install. Just a thought.
Old May 20, 2013 | 02:13 PM
FOURSPEEDVETTE's Avatar
FOURSPEEDVETTE
Old May 20, 2013 | 09:14 PM
OchoCincoC4
4th Gear
hmm - well any ideas on where these toggle switches ground to? Does the window power get ground from a common area. I see two wires going into the passenger side motor blue/white and tan - both when tested with meter show good power up/down..but still scratching my head on how the motor itself is grounded... thanks all for any help - Kevin
Old May 20, 2013 | 10:36 PM
C4boy's Avatar
C4boy
I'm with ejscarfo... I'd have a hard time believing both your motors went at the same time. When you say you have power at the motors, do you mean you have 12V at the motor when pushing the toggle switch in either direction?
Old May 20, 2013 | 11:01 PM
ccrazor's Avatar
ccrazor
St. Jude Donor '08-'09
This is the schematic for the 84, s/b similar.. If you open up the center console to the switches you can check for both power and ground at the switches..
Old May 21, 2013 | 07:21 AM
OchoCincoC4
4th Gear
hmm this seems good - I will check this evening on his, any ideas on where 'Instrument Panel Ground' is located? suspect this is the common place hmmmm ty for sharing!
To C4 Power Windows - HELP - 1985 - HELP
