tach filter help please
The other end goes thru the firewall into the interior.
The tach filter itself should be bolted to the 3rd bell housing bolt
on the Driver side. There is a wiring harness that may also be
attached to the same bolt making it hard to see the tach filter.
If that bellhousing bolt needs to be removed most people
use 2 to 3 ft of 1/2 drive extensions and a universal to get to it
from under the vehicle.
Some people after replacng a tach filter, change the location where
they bolt the tach filter to make it easier to replace in the future.
The tach filter bracket is ground for the filter so it needs to be
grounded. Doesn't explain your problem because it doesn't need
to be unbolted to remove the heads.
