C-4 Voltage Problem
Old May 25, 2013 | 06:32 PM
whmartin98's Avatar
whmartin98
Cruising
Default C-4 Voltage Problem
Hi Guys looking for a few suggestions. I have 85 corvette with digital dash. Just the other day I got an alarm with a red bar saving voltage problem. It is putting out between 17.8 to 18.2 on the digital display. I know the battery is good and I just replaced the (alt) today, with no change. I still get the alarm with 18.2 volts. Any suggestions. Tks Wayne
Old May 26, 2013 | 02:24 AM
Cliff Harris's Avatar
Cliff Harris
That voltage is way too high. I know on my car (different ECM) that the ECM won't let you start the car if the voltage is too high.
It's possible the voltmeter is just reading incorrectly. The way to find out is to measure the voltage at the alternator while the engine is running. When the engine is not running you will be measuring the battery voltage.
Old May 26, 2013 | 08:28 AM
Paul Workman's Avatar
Paul Workman
with Cliff. If you changed the alternator, and still are getting the (dash) high voltage problem, I'd want to put a volt meter on it to see what is really going on, as "step -1".
Old May 26, 2013 | 09:09 AM
c4cruiser's Avatar
c4cruiser
Just as suggested in your same thread in the C4 Tech section.
But do the check not only at the alternator, but at the battery (both with engine running and off). I would make sure the battery has a full charge before testing voltage. Battery voltage with a full charge (engine off) should be around 12.7 to 12.8 volts.
A good alternator should provide around 14.1 to 14.3 volts after engine start, then slowly drop to around 13.6 to 13.8 volts depending on what accessories are turned on.
Where did the alternator come from? One of the chain parts stores? Sometimes the part store rebuilds are poor quality. You may have gotten one that is bad. I would take it back and get another one. If funds allow, consider buying a brand new alternator. AC Delco or Bosch are good choices.
Old May 27, 2013 | 07:55 PM
whmartin98's Avatar
whmartin98
Cruising
Hi guys, hope everyone had good weekend. I did as you suggested. I have confirmed the original alternator was good and installed back in car. I check with volt meter at battery with engine not running got 12 volts , and with engine running about 14.5. Inside the car on digital dash I still show alarm and 18.2 volts. My next step would be to replace the ECM, unless someone has a better idea, let me know, Wayne
Old May 28, 2013 | 12:15 AM
Cliff Harris
The function that displays the voltage is contained entirely in the instrument cluster. The ECM does not have anything to do with that.
Your problem is in the instrument cluster.
Old May 28, 2013 | 10:23 AM
whmartin98's Avatar
whmartin98
Cruising
Hi Cliff
Thanks for the information, I thought somehow changing the ECM may correct my High voltage problem. Sorry to hear it is in the cluster, If this is my only trouble in the cluster which it is, I guess I will live with it until another issue in the cluster comes up. Again Thanks for your thought, Wayne Tn.
Old May 29, 2013 | 12:45 AM
Cliff Harris
Well, you could always look at coolant temperature instead...
I just remembered that the cluster will switch to the display that is showing the problem automatically. You might not be able to switch to coolant temperature. I know mine switches to the voltmeter if the voltage is below 11.5 volts. I don't know if it does that if the voltage is too high.
Old May 30, 2013 | 11:35 AM
whmartin98's Avatar
whmartin98
Cruising
Thanks for the thought, you are correct, it will switch to the alarm state, showing 18.2. By any change does anyone the the have the name of a firm the is fair in their pricing and does a good job repairing and rebuilding the dash. It appears this is my only option, Tks Wayne Tn
Old May 30, 2013 | 12:30 PM
thecatmac's Avatar
thecatmac
http://www.batee.com/index.htm
To C-4 Voltage Problem
