88 intrument panel issues
Old May 30, 2013 | 02:46 AM
Ray Rust's Avatar
Ray Rust
Default 88 intrument panel issues
Okay I pulled the dash apart to replace globes in the clusters , electronic A/C and main display ..good news is all the dash lites work , the bad news is , the cool button no longer lowers temperature and in the the main cluster , I've lost fuel range and fuel gauge .... kicking myself shoulda left it alone ....in need of some advice on what I've done wrong ...anybody ??? Newby from Aus ....Ray Rust
Old May 31, 2013 | 03:07 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Check that you didn't move any of the LCD panels nor their mating parts.
Also check that multi-pin connector between PC boards, see if you loosened any of their solder connections.
Open the A/C controller and rub the PCB card fingers with a pencil erasure to clean them.
Old May 31, 2013 | 03:45 AM
Ray Rust's Avatar
Ray Rust
I've tried the eraser on the contacts ,,, didn't solve my problem , still looking for suggestions thanks ...
To 88 intrument panel issues
