Front badge help
Old May 31, 2013 | 09:27 AM
stc's Avatar
stc
Default Front badge help
I am trying to put on a new front hood badge! I have located the two holes to reach the nuts. My question is what size are the nuts and is there any easy to get the nuts off given the location.
Old May 31, 2013 | 09:29 AM
stc's Avatar
stc
Default Front badge help.
I forgot to mention it is a 1985 C4!
Old May 31, 2013 | 09:47 AM
Goldcylon's Avatar
Goldcylon
Magnetic Socket works. Does your replacement badge have pins or are they threaded ?
Old May 31, 2013 | 10:11 AM
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
85's are pins with those weired self threading nuts. Can't remember what they are called.
Op can't know anyway until off
Old May 31, 2013 | 10:31 AM
DaveP85C4's Avatar
DaveP85C4
Pal nuts. The size of the hex for the badge is 3/8, 7/16, or 10mm. It's not fussy.
Old May 31, 2013 | 11:40 AM
Cruisinfanatic
need to put something like sticky tape on the socket or they'll go bye real fast and won't get them back. Not sure they are not aluminum and magnet won't work.
Old May 31, 2013 | 11:50 AM
Little Red L98's Avatar
Little Red L98
Goon Squad BS Detector
2018 C4 of the Year Winner
2017 C4 of the Year Finalist
St. Jude Donor '15, '17
I had the same problem a couple of weeks ago. What a PITA! I've had no problem using the product at the end of the thread. It should be as easy to remove as it was to install.
http://forums.corvetteforum.com/c4-g...od-emblem.html
Old May 31, 2013 | 11:45 PM
Cliff Harris's Avatar
Cliff Harris
Those are speed nuts. 10mm.
Old Jun 1, 2013 | 09:38 AM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Don't lose the nuts or the socket while doing this as they will slide around in the channel under the front of the hood every time you turn a corner.
Don't ask how I know this!
To Front badge help
