Console lid button..
Old Jun 9, 2013 | 04:25 PM
gears's Avatar
gears
Default Console lid button..
I guess the spring came out of the button,cause the console lid will not latch since the spring seems to have disappeared.Where do I get a spring or whats the fix?? 96 LT4
Old Jun 9, 2013 | 04:34 PM
Joycey989's Avatar
Joycey989
When you try to close it it stays but the button does not pop back out to show its closed right? Or what exactly happens?
Old Jun 9, 2013 | 04:40 PM
daddysvet92's Avatar
daddysvet92
There is a thin spring in the buttons and they do break after time!
You'll have to buy a new button that has the spring included with the package!
Old Jun 9, 2013 | 04:57 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
MAM catalog lists the following related part; now sure what differs in '96?
603-198: 1984-1995 Console Lid Spring: $7.99
I just checked their web site and that part is listed for 1984-1996 Corvette???
Might be worth a call to them.
Old Jun 9, 2013 | 05:57 PM
vittal's Avatar
vittal
Same thing happened to me. The spring popped out and I never found it. Still haven't found a solution to this. I don't feel like paying 30 buck shipping for a 7 buck spring.
Old Jun 9, 2013 | 06:02 PM
65Z01's Avatar
65Z01
On my prior '88 that spring broke just after I got the car and I didn't know I could buy anther one so I MacGyvered it.
I removed the lid and then the inside plate to expose the button & broken spring. I found a small ball-point pen spring, cut it to length and inserted behind the button. That "fix" lasted for >12yrs of ownership...
Old Jun 9, 2013 | 06:06 PM
gears's Avatar
gears
65Z01 I like the way you think.I believe I will see if I can MacGyvere it myself...
Old Jun 9, 2013 | 07:50 PM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Buy a used door assembly from flea bay or a parts yard.
There maybe other parts that you need when your working on this..
Old Jun 9, 2013 | 09:02 PM
vittal's Avatar
vittal
Thanks that's exactly the type of solution I was thinking about for my button when I get around to it.
Old Jun 9, 2013 | 09:04 PM
65GGvert's Avatar
65GGvert
http://www.ecklerscorvette.com/corve...1984-1996.html
Old Jun 10, 2013 | 04:16 AM
gears's Avatar
gears
Thanks for all the replies guys !
Old Jun 14, 2013 | 09:41 PM
gears's Avatar
gears
Well,lid works now ! Took it out,spring was broke so I got a couple ball point pen springs,McGivered them on there,put it back togather and waalaah..
To Console lid button..
