Need some help
Old Jun 13, 2013 | 09:20 PM
1993C4LT1's Avatar
1993C4LT1
Default Need some help
What's up guys/gals. It started yesterday, I went to go pump gas and the car didn't want to start. I waited about 5 minutes, then she started like normal. When the engine didn't start, the engine was at 160 degrees. Today, I went WOT. When I got to about 40-45 MPH, the car didn't shift and the engine turned off, and the service engine soon light came on. Luckily I made it home. I wanted to put the C4 in the garage, I go back outside to see if it would start, and it did. Started up completely normal. Oh, when the engine started back up, there was no service engine soon light on. Car is a '93 LT1.
Any ideas?
Old Jun 13, 2013 | 09:56 PM
don hall's Avatar
don hall
Maybe a check for codes might help........
http://www.gnttype.org/maint/malf.html
Old Jun 13, 2013 | 09:57 PM
93Rubie's Avatar
93Rubie
See if you have any stored codes for starters.
Old Jun 14, 2013 | 12:39 AM
vetteoz's Avatar
vetteoz
Define wouldn't start?
No crank or crank - no fire ?
Old Jun 14, 2013 | 01:52 AM
lt4obsesses's Avatar
lt4obsesses
No start, shuts off when hot. I put money on the ICM.
On second thought, need the answer to Vetteoz question.
Crank, no fire ICM
No crank, check the 'security' light on the dash. If it is on when you trun the key, it's a vats issue.
Old Jun 14, 2013 | 10:48 AM
1993C4LT1's Avatar
1993C4LT1
Thanks for the responses. No, the security light wasn't on when the car wouldn't start. It would crank, just wouldn't fire up. What really scared me was when I was doing WOT and the engine turned off.
Old Jun 16, 2013 | 12:15 AM
TorchTarga94's Avatar
TorchTarga94
Just had this same issue. My culprit was the opti.
Old Jun 20, 2013 | 05:29 PM
1993C4LT1's Avatar
1993C4LT1
lt4obsesses was correct. My dad helped me today, and we replaced the ICM. Problem solved, Vette is well!
Thank you all for the help.
Old Jun 20, 2013 | 06:03 PM
mrmtrtrnd's Avatar
mrmtrtrnd
Glad to here your car is up and running again. I had the same issue and fix a while back. The ICM is a easy and pretty cheap fix and wish they were all like that.
Old Jun 20, 2013 | 08:07 PM
braveheart3158's Avatar
braveheart3158
What is the icm?
Old Jun 20, 2013 | 08:56 PM
1993C4LT1's Avatar
1993C4LT1
Originally Posted by braveheart3158
What is the icm?
Ignition control module. Behind the opti spark.
Old Jun 20, 2013 | 11:20 PM
mrmtrtrnd's Avatar
mrmtrtrnd
Mounted on the head, front passenger side and thats why it is so important to use the heat sink on the installation.
To Need some help
