Oil change
Old Jun 25, 2002 | 10:57 AM
Rex Ruby's Avatar
Rex Ruby
Philly 'Burbs Events Coordinator
Default Oil change
I have 400 miles till I'm due for my next change. Tomorrow I have to take a 500 mile trip and return on THursday, putting me about 600 miles over my 3000 mile interval. What would you do?
Old Jun 25, 2002 | 11:30 AM
91-Z07Coupe's Avatar
91-Z07Coupe
Default Re: Oil change (Rex Ruby)
Well, if you are using Mobil 1, you can safely go more than 3000 miles between oil changes. Oil has changed so much in the last 20 years, that the 3000 mile interval is really outdated. The only reason that oil change places keep writing down the 3000 miles on the little oil change reminder is to get you to come in more often so they make more money. New cars these days usually say somewhere between 5000 and 7000 miles between oil changes, and that's on conventional oil. So don't be worried about going 3600 miles between oil changes.
Old Jun 25, 2002 | 11:44 AM
vader86's Avatar
vader86
Default Re: Oil change (91-Z07Coupe)
If youre using Mobil 1 i dont see any problem with waiting.
Old Jun 25, 2002 | 12:14 PM
Scoob's Avatar
Scoob
Regardless of what oil you are using, if you have time to change it before you go, change it. But if you don't have the time then don't worry about it, change it when you get back.
Old Jun 25, 2002 | 01:36 PM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Default Re: Oil change (Scoob)
Regardless of what oil you are using, if you have time to change it before you go, change it. But if you don't have the time then don't worry about it, change it when you get back.[/QUOTE]
Old Jun 25, 2002 | 02:01 PM
85vetteguy's Avatar
85vetteguy
You will be fine if you wait.
Old Jun 25, 2002 | 02:08 PM
Stv50's Avatar
Stv50
I'm faced witht the same problem. I went ahead and got the oil change. I also had them check all fluid levels, tire pressure, etc because I'm going on a trip. Gives you peace of mind before leaving.
[Modified by Stv50, 12:08 PM 6/25/2002]
Old Jun 25, 2002 | 03:05 PM
Rex Ruby's Avatar
Rex Ruby
Default Re: Oil change (Stv50)
Thanks for the feedback :cheers: ***EDIT***
Was going to wait, but just went to the store and I'm w/in 300 miles and the change oil ight is on so going to do it:yesnod:
Old Jun 25, 2002 | 06:53 PM
GlockLT4's Avatar
GlockLT4
Default Re: Oil change (vader86)
You'll be fine.. just go on the trip.
Old Jun 25, 2002 | 08:15 PM
RichS's Avatar
RichS
I'd just replace it. Not like it is a hard thing to do.
Old Jun 25, 2002 | 08:23 PM
Alchemist's Avatar
Alchemist
NC Events Coordinator
If it was me...i'd wait. Most folks consider the 3K oil change "excessive" but harmless.
Old Jun 25, 2002 | 09:19 PM
bac22's Avatar
bac22
Default Re: Oil change (Alchemist)
3K is way way way too excessive if you are using Mobil 1 Synthetic.The change oil light is there for a reason. It is not just based on milage, but oil temperature and bunch other algorithyms that were explain to me once, but much too complicate to recite now.
Old Jun 26, 2002 | 04:31 AM
VETTENV's Avatar
VETTENV
Cruise-In V Veteran
My brother has been a mechanic for 35 years. He tells me that with synthetic you can easily go 7,000 between oil changes. I still do it fairly close to 3,000. Guess it's just habit! :D
Old Jun 26, 2002 | 04:36 AM
skeet's Avatar
skeet
Default Re: Oil change (9vette3)
Thinking about all the dirty oil running around in your engine can ruin the whole trip. I say change it and drive with a smile : )
Old Jun 26, 2002 | 08:41 AM
tgroghan's Avatar
tgroghan
I just feel better after my Vette has its oil changed. Then again I feel that same way after I wash it, I"m just as strange as the next vette owner.
What ever you decide to do, at least check the level of it before you go. An ounce of prevention is with a pound (US) of cure.
Thad
Old Jun 26, 2002 | 11:57 AM
96YellowC4's Avatar
96YellowC4
I have been going 6k-7k on my oil changes with synthetic oil. I haven't noticed any detrimental effects...even on our suburban that we use for towing.
Old Jun 27, 2002 | 02:46 PM
OleDog's Avatar
OleDog
Default Re: Oil change (96YellowC4)
That was some long thread. Good thing the question wasn't about spark plugs...... :smash:
To Oil change
