Rebuilt Engine
Old Jun 16, 2013 | 11:24 AM
dlee425's Avatar
dlee425
Default Rebuilt Engine
How can you tell if the engine has been replaced. were all 86 alum head engines black ?
Old Jun 16, 2013 | 06:31 PM
PAINTER MAN's Avatar
PAINTER MAN
All L98's were painted black.
Old Jun 16, 2013 | 06:41 PM
ghoastrider1's Avatar
ghoastrider1
not all 86 engines had alum heads .. just the later ones. there is a pad on the pass. side, front, of the engine that has numbers on it that should match your vin number
Old Jun 16, 2013 | 06:48 PM
JackDidley's Avatar
JackDidley
late 86 and all verts got aluminum heads. Early 86 got iron.
Old Jun 16, 2013 | 07:03 PM
dlee425's Avatar
dlee425
Will check the number on the block to see if it matchs the vin number. It is an alum head engine. I had to replace the cooling hoses for the oil cooler and noticed the block was black.
Thanks,
Donnie
Old Jun 16, 2013 | 07:35 PM
zr1fred's Avatar
zr1fred
Veteran: Marine Corps
Short block should be GM satin black. Aluminum heads were not painted.
To Rebuilt Engine
