A.I.R. pump delete kit.
Anything connected to the pump ( both in and out ) gets removed
The one way valves on the exh manifolds can be left in place and sealed with rubber caps ( as used for heater lines ) or the valves removed and the threaded pipe sealed with 1/2 NPT pipe cap.
Tape up the connectors to the divertor valves because wires are hot with key on
No SES light because there is no feedback to the ECM on the AIR system
belt still fit. i left my diverter check valves on for now untill i install the headers this fall PO already removed the Cats.
I am also installing under drive pulleys and figured that "while I am in there" I might as well install a new water pump. Just pushed the car out into the driveway and used a gasoline powered power washer to blast the front of the engine and the stuff below it at 3,000 PSI. I am soaked and the driveway is flowing rainbow-colored water! I am glad I covered everything up good because the greasy black pieces of crud went everywhere! I am going to have to wash the car tomorrow.
I'll get some before and after pics up tomorrow after it all dries.
Fun in the garage! (actually out in the driveway).
You can remove all of the hoses and plastic lines without causing any issues at all. There is no electrical relationship between the AIR components and the A/C compressor. There is a single plug with two wires going to the A/C compressor; just leave that connector in place.
There will be a vacuum line to the AIR valve so get a rubber vacuum line cap to plug the line. The two electrical connections can simply be wire-tied out of the way.
You didn't say what AIR pump eliminator kit you are using, but make sure you check for any difference in the diameter of the OEM AIR pump pulley and the kit pulley. You may have to use a serp belt that is a couple inches shorter. It depends on the kit.
Also, don't except these 20hp gains being advertised from an AIR delete. It's consistently been show to be a false claim.
You'll be lucky if you get 1hp...and that's gonna be due to dyno variance from run-to-run.
1) To increase horsepower, or because they are installing engine components (or whole engines) which are incompatible with them. This is what I assumed in your case.
2) To attempt to resolve some issue with the way the engine is running.
If you are removing it for the first reason, I can understand that. Significant mods sometimes result in removal of the equipment. Headers, intakes, etc... sometimes just do not allow for them. This I can live with, especially on a track or drag car. The second reason is just dumb. If your stock engine is not running right, then defeating a piece of equipment that was designed to be part of the system in an attempt to "right" it is a lazy shortcut. Yes, there is the odd occasion where the emissions equipment cannot be repaired and is truly the cause- but most often it's just removed because it is a convenient scapegoat for someone who does not even know what the equipment does.
Your reason is, in my opinion, of less value than either of those two, especially if the engine is running well with it in place.
The old-car hobby is on the defensive. It's been attacked for years as an environmentally damaging endeavor full of old cars spewing smog and leaking massive quantities of gasoline and oil all over our highways while we rip by at insane speeds with loud exhausts. From car-crushing rebates and buybacks to legislation prohibiting hobbyists from parking their cars in their driveways, any number of legal attacks have been visited upon our hobby. And when someone uninitiated in this hobby reads that you want to pull off your A.I.R. pump, which robs a tiny sliver of horsepower from your engine but allows a more complete burning of hydrocarbons by your engine, because you don't like THE WAY IT LOOKS, then their feelings about old car guys are reinforced. And your ownership of a C4 makes you an "old car guy", like it or not.
Further, the word "unnecessary" is ridiculous in this instance. The engineers who designed and installed the equipment on that car did not do so because they had no better way to spend the money. I'm guessing that you could not even tell me what the A.I.R. system does without Googling it.
Your attitude is worse than worthless- it makes us look bad to people who are already highly suspicious of our hobby and would love to see these cars crushed up and recycled into nice, happy, Nissan Leafs and Priuses.
If that's truly your only reason for junking it, perhaps your time would be better invested in figuring out a way to make it better looking- plating, polishing, perhaps a set of custom stainless tubes or something equally cool.
