1988 wheel replacement
Old Jun 16, 2013 | 09:07 PM
envirotrans's Avatar
envirotrans
Default 1988 wheel replacement
Will these wheels fit my 88 or is there going to be a rubbing problems if they well fit what size tires
Z06 factory wheels off of a 2001 Z06
Front Size - 17x9.5
Front Offset - +54mm
Front Back Spacing - 7.38" (187.35mm)
Rear Size - 18x10.5
Rear Offset - +58mm
Rear Back Spacing - 8.03" (204.05mm)
Bolt Pattern - 5x120.7
Fitment - 2001-2004
Material - Alloy
Finish - Brushed Aluminum
Old Jun 17, 2013 | 11:58 AM
bob guzzy's Avatar
bob guzzy
You can definitely use the 17x9.5's all the way around.
I think the 10.5's are going to be too deep for the rears without shimming it outward, then if you do use them I think you will have tire rubbing or sticking out too far problems.
Old Jun 17, 2013 | 12:31 PM
envirotrans
Thanks for the reply I may just get them and use the 17ins on the rear for playday
Old Jun 17, 2013 | 04:12 PM
WVZR-1's Avatar
WVZR-1
This looks to be the same question I answered last evening! Have you posted this a few times?
Anyway I think your fine check your other thread where ever that was
Here it is:
http://forums.corvetteforum.com/c4-t...placement.html
Old Jun 17, 2013 | 05:37 PM
envirotrans
Yes. I posted here and in tech to get more replys, the person selling the wheels only wants 300.00 for the set. But I don't need a headache from the 18in if they have to be shimed and after looking at the cost. I well use the cash and get body kit instead thank you for your time.
PS. Cra list reno. Search for. Corvette wheels. last post was 6-13-13
To 1988 wheel replacement
