Targa top question
Old Jun 17, 2013 | 05:04 PM
92lt1vet's Avatar
92lt1vet
Default Targa top question
Hey guys just found a good deal on a bronze tint targa top,will it look not right on my 1992 aqua metallic coupe as its not the color it came with never looked at one up close ,also it came off a 1990 will that fit my 1992
Also there's no gm markings on it seeing its aftermarket will I have fitment issues also
Thanks mike
Old Jun 17, 2013 | 05:08 PM
csthews's Avatar
csthews
Thanks mike
I put a blue tint top on my polo green '95. In the sun, you can't really tell the difference. You will probably notice the same results with the one you are looking at.
Old Jun 17, 2013 | 05:21 PM
92lt1vet's Avatar
92lt1vet
Thanks for the imput
Old Jun 17, 2013 | 06:32 PM
fatboywilly's Avatar
fatboywilly
They look darn near black from the outside. You can't tell the blue ones are blue except from the inside.
Old Jun 17, 2013 | 07:21 PM
RollaMo-LT4's Avatar
RollaMo-LT4
St. Jude 15 Year Donor
2021 C4 of the Year - Unmodified Finalist
St. Jude Donor '10 thru '25
They only came in two tints, blue and bronze.
And from the outside looking in, they both look black.
Factory tops from 1989 - 1996 have the same mounting brackets.
WVZR-1's Avatar
WVZR-1
Thanks mike
Check your top and check a couple of things, 1. is there a three sided "steel" molding that is a pressure fit on the front and both sides. The molding is one piece. 2. Center of the rear edge maybe 1 1/2" from the edge there is likely a manufacturer "bug" visible only from the outside. What does that "bug" say?
The fit '90 - '92 isn't an issue.
Just "maybe" there will be a portion of the VIN displayed on the front of the left rail on the top. Here's one from a '96:
That might look familiar to "RollaMo-LT4"
Old Jun 17, 2013 | 09:53 PM
92lt1vet's Avatar
92lt1vet
Ok thanks guys very helpful, I might just take my top with me also just to make sure everything lines up
Old Jun 17, 2013 | 10:58 PM
ghoastrider1's Avatar
ghoastrider1
the difference will be in the FRONT alignment hardware, not the rear hardware. I put a 91 top on my 86, had to change out stuff.
Old Jun 17, 2013 | 11:11 PM
RollaMo-LT4
The top brackets were different between an '86 and '91.
The OP has a '92, and they use the same mounting as the '90 top that he is looking at.
Old Jun 17, 2013 | 11:25 PM
92lt1vet's Avatar
92lt1vet
thanks RollaMo-LT4 very helpful
thanks everyone else also
Old Jun 18, 2013 | 12:08 AM
Netfly's Avatar
Netfly
I suggest you look through both tops from the inside out. The sky just didn't look right with the bronze tint, the blue looks a lot better to me.
Old Jun 18, 2013 | 10:06 PM
92lt1vet's Avatar
92lt1vet
That's the thing I'm picking up an exhaust so I'm not taking my car,taking my explorer I guess I can just hold it up and look through it
Old Jun 18, 2013 | 10:12 PM
WVZR-1's Avatar
WVZR-1
Make sure you do because if not you can easily overlook the crazing of the tops regardless of color. Check the exterior for the protective coating showing signs of deteriorating, scratches and mars and minor cracks at edges that will become major before you maybe even get it home. Check the frame for cracks also.
Old Jun 18, 2013 | 11:05 PM
92lt1vet's Avatar
92lt1vet
Wv-zr1 it's brand new but I'm def gonna check everything,still has plastic on it
To Targa top question
