What is this wire?
Old Jun 18, 2013 | 08:20 AM
SirNut's Avatar
SirNut
Default What is this wire?
Hi guys. just opened up my console and found a wire that had been cut and duct taped so it was nice and perfectly safe
also, are there supposed to be two of these lights for the shift indicator?
I don't have a FSM yet so i'm not sure how to go about tracing these wires. can someone please help?
Old Jun 18, 2013 | 08:22 AM
SirNut's Avatar
SirNut
here are base links because stupid img code doesn't seem to be working
first:
http://sdrv.ms/11M1c8t
second:
https://skydrive.live.com/redir?resi...NB6lE3PcEFeRAw
Cruisinfanatic's Avatar
Cruisinfanatic
From: Clifton Park, NY ............Clearwater, FL ... 85 Original Owner
Old Jun 18, 2013 | 08:29 AM
SirNut's Avatar
SirNut
how did you get the picture to display properly? I used the [IMG]value[/IMG] code on the links. thank you for getting one of them to display however. Can anyone tell what this goes to??
Old Jun 18, 2013 | 08:49 AM
Cruisinfanatic
go to the original picture where you put it online and copy/paste it here
Old Jun 18, 2013 | 11:14 AM
383vett's Avatar
383vett
Not sure, but it could be the console hatch light connector.
Old Jun 18, 2013 | 11:20 AM
corvetteronw's Avatar
corvetteronw
Cruise-In VII Veteran
Cruise-In VIII
St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
There is a place for 2 shift indicator bulbs but only 1 was used by the factory. Some have wired the other one to be hot and put in another bulb but it makes the indicator too bright. I have read that you can put 2 LED bulbs in there and this makes the shift indicator easy to read and gives a distinctive look.
SirNut's Avatar
SirNut
I dont think so, the console light works fine. Im referring to the orange wires in duct tape. There's also a black wire with the wires but it isn't in the tape because it must be the ground
Old Jun 18, 2013 | 11:31 AM
lusor's Avatar
lusor
Does are the accessorie wires.One of them is hot at all times and the other one I think is switched .
Old Jun 18, 2013 | 11:39 AM
SirNut's Avatar
SirNut
You don't say... Ill hook my meter up to them later to check that. Thanks for the help!
Old Jun 18, 2013 | 01:16 PM
WVZR-1's Avatar
WVZR-1
I'm quite sure you'll find that to be so.
Old Jun 18, 2013 | 01:20 PM
davewhtt's Avatar
davewhtt
Old Jun 18, 2013 | 02:01 PM
c4cruiser's Avatar
c4cruiser
One will be always hot (the orange one, IIRC) and the other is hot with the ignition switch in the ON position. Each wire has a 10A capacity.
To What is this wire?
