computer removal?
Old Jun 27, 2013 | 02:56 AM
D.j. 88's Avatar
D.j. 88
Default computer removal?
Hi, does anyone know how, and where to remove the ecm from a 1988 C4 Corvette?
Old Jun 27, 2013 | 04:09 AM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Drop the PS hush panel and you will find the ECM just up behind the center.
Remove two screws, slide it out and down.
Unplug the two wire harnesses and voila.
Old Jun 27, 2013 | 09:07 AM
Muffin's Avatar
Muffin
My first question would be:"Why do you want to remove it?".
Old Jun 27, 2013 | 02:13 PM
D.j. 88's Avatar
D.j. 88
Default thank you
My car turns over but no spark. I replaced the ignition control module cap and rotor plugs fuel pump. People ive talked to said the computer might be the problem + the engine icon comes up all the time.
Old Jun 27, 2013 | 05:07 PM
Muffin's Avatar
Muffin
Quit throwing parts at it. Second follow the instructions here:
http://www.extreme-check-engine-ligh...%20Decoder.htm
Retrieve the fault codes and report them here. The SES light (engine icon) is telling you where to start. At this point pulling the ECM will most likely do more damsge than resolve issues.
Old Jun 28, 2013 | 01:05 AM
D.j. 88's Avatar
D.j. 88
Thank you!!! I appreciate it!!
Old Jun 29, 2013 | 10:22 PM
Cliff Harris's Avatar
Cliff Harris
Originally Posted by Muffin
There is a lot of misleading information on that site. Most of those error codes are for much later ECMs and don't apply to yours.
I'm away from my home computer and don't have the links to several posts on this subject on the Corvette Forum.
Here is a link to the codes in the '86 - '89 ECMs:
http://home.earthlink.net/~cliff_har...Misc/misc.html
Old Jun 30, 2013 | 04:27 AM
D.j. 88's Avatar
D.j. 88
Thank you Cliff!!!!
To computer removal?
